A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Vehicle weight?
Old 11-09-2010, 12:54 PM
Vinb8's Avatar
Default Vehicle weight?
How much does the a4 b8 weigh?
Old 11-09-2010, 01:22 PM
markinarch's Avatar
Multitronic® Tiptronic® Manual
Curb Weight 3527 lbs. [1600 kg] 3715 lbs [1685 kg] 3626 lbs. [1644 kg]
You can find all this stuff under detailed specifications on AudiUSA.COM
Old 11-10-2010, 07:17 AM
m444's Avatar
Interesting the Audi website list similar weights for the 2011 S4. The S4 engine only weights 418 lbs.
http://models.audiusa.com/s4-sedan/d...#chassis_specs
B8 S4 Stronic - Curb Weight = 3714 lbs
B8 S4 Manual - Curb Weight = 3637 lbs
Of course add a 175 lb driver & a full tank of gasoline (~ 104 lbs), gives about 279 lbs to the claimed weight.
S4 Stronic - Curb Weight with driver & full tank = 3714 lbs + 279 lbs ~ 3993 lbs
S4 Manual - Curb Weight with driver & full tank = 3637 lbs + 279 lbs ~ 3916 lbs
Old 11-10-2010, 10:02 AM
need_TQM's Avatar
Several have reported that the S4 weight on Audiusa is wrong.
IIRC, the 2.0T engine is supposed to be 317 lbs.
Old 11-10-2010, 12:51 PM
Vinb8's Avatar
Ok thanks for the info man.
Old 11-10-2010, 07:11 PM
m444's Avatar
Most of the test articles show the tested weight just under 4000 lbs, but that is with the driver and fuel added.
Old 11-20-2010, 02:12 PM
equ
equ's Avatar
S4's weigh in the 3900-4000lb range. A4 2.0T 6MT's are in the 3650-3700 range, if I had to guess. I researched this at some point when I was trying to decide between the two (and looked up various road test and scale measurements of US spec cars).
Old 11-20-2010, 08:58 PM
m444's Avatar
The S4 3.0T & A4 2.0T engine weights are only 100 lbs difference.
Old 11-22-2010, 10:49 AM
m444's Avatar
The quoted weight differences are mostly dominated by test weight vs dry weight. Test weight includes fuel and the driver, plus maybe some test equipment.
Old 11-23-2010, 08:34 AM
validA4's Avatar
Curb weight includes gas. Dry weight does not.
kdkrone
Q7 MKII Discussion
08-15-2020 09:51 AM
doonie
03-06-2007 05:03 PM
S4_4MY30'S
05-24-2002 12:08 PM
EighTT
05-14-2002 06:43 AM
CSR
02-24-1999 08:04 PM
Quick Reply: Vehicle weight?
