WEAK BATTERY Warning
I had stopped for gas and turned off my car. While waiting, I notice the screen says 'Weak Battery' then something about 3 minutes until it shuts down.
I have 39k on the car. My Audi care just ran out (of course) and I haven't done my maintenance yet only because I am not paying $500+ to Audi, so I need to schedule with my mechanic.
Do I need to replace it or just run a diagnostic on it to see if there is another issue? Winter is here, so I don't want to get stuck with a dead battery, but I wouldn't think it would be due for replacement yet.
Thanks
Thanks
Do you have the VCDS tool? Is this the original battery, Trlyka?
Hey there, just wanted to know if it was the battery in the end? Or if not, what else it could have been? I have just had my battery replaced as I also was experiencing random Battery Weak messages whilst driving. Audi said it was the battery as there was an aftermarket one in there, they changed it, after a week the messages started popping up again. Twice I had to pull over, turn off the car and then restart it. Back with Audi getting more checks. Getting very worried now that I have brought a Lemon and a half 😕
Did they diagnose the battery and the charging system, or were just guessing? If the charging system does not operate correctly, of course the battery can not stay charged.
Who knows, Audi say they spent 6 hours initially diagnosing that the battery was at fault. Took it back to the dealer for more checks, still couldn't tell me anything concrete, just second guessing thinking it's the alternator having problems charging the battery, want to charge nearly $4k AUD to replace it. It really is a weird one as I took the car for a 20km drive today, roof down and media system playing, no 'Battery Weak' messages whatsoever, just so random.
So I am still getting battery weak messages and decided to go and buy a volt meter to do some fault finding of my own however on the way home the battery got to the point where it was so low that I started getting a gearbox malfunction message so I immediately pulled over and turned off the engine. When I tried to start the car again it was dead. Ended up Calling roadside assistance to get the battery jumped started so I could get home. He checked the alternator and it was showing 13.07v so it looked to be charging. I got the car home and again checked it myself, it was showing around 13.24v. So later in the day I decided to have another check to see if there was any drain. Initially the battery was showing 12.04v before starting the car. After starting it, I noticed it dropping gradually below 12v, it got to about 11.87v which to me indicates that the alternator was not working or not turning, however about 30 mins later I checked again and it was again working as the voltage had gone up to 13.24v. Literally just checked 30 mins later and it has dropped to 11.48v. Now I'm stuck between thinking it either being a faulty alternator (or a faulternator) or the pulley is loose/worn. Any thoughts or suggestions? Thanks all
