A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
What to check for my next service @ 45k miles
Old 09-30-2018, 09:26 AM
net1994's Avatar
Default What to check for my next service @ 45k miles
Hi folks - I have a 2013 A4 quattro sedan. It will soon hit 45k. Not a lot of miles to be sure. However it's already had a wheel bearing replaced and the u-joint stiffed up a few months ago. For the U-joint, my mechanic greased it up for $70 and that 'fixed' it. Better than the $600-800 repair job the dealership wanted for it. In the next few weeks I will have to replace the rear rotors and pads and get a oil change. I also want them to flush the brake lines. Besides this and checking for usual wear and tear (leaks, belts, seals, etc), anything else you can think of to check at this point or to check/replace for preventative service? For it's age, it's relatively low mileage and should be good mechanically for some time to come. But a bad wheel bearing so 'young' and tired U-joint make me more cautious.
Thanks!
Old 10-08-2018, 05:42 PM
Bink187's Avatar
transmission drain and fill, rear diff fluid would not be out of the question for me at 45k
Old 10-09-2018, 06:41 AM
net1994's Avatar
How much extra would that add $$?
Old 10-09-2018, 01:34 PM
Bink187's Avatar
Mine was $289 out the door, a pan drop w/filter and rear diff @AAMCO of south Tampa.
Old 10-17-2018, 10:16 AM
jatinshetty26's Avatar
Intake filter replacement and the pollen filter also would hurt. Its fairly inexpensive and something you can do yourself.
At 50k I did a coolant flush as well...
MP4.2+6.0
18
10-24-2022 04:43 PM
made2last
02-13-2007 11:43 AM
eawstyle
10-14-2004 04:23 PM
A4MIKE
12v V6 Discussion
10-12-2004 01:27 PM
CrazyINP-12V Ivan
11-27-2000 08:22 PM
Quick Reply: What to check for my next service @ 45k miles
