A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Will it work
Old Jun 27, 2019 | 01:28 PM
ehale's Avatar
Default Will it work
I have a 2010 A4 that is in need of an engine, I have found a few 2015 engines with low miles but they are not cheap. today I found a complete 2015 A3 the whole car totaled for less money than just an A4 engine) but the engine sits in the car sideways. my question is will the engine work in my A4?
Old Jun 28, 2019 | 02:07 AM
ehale's Avatar
Or is there a list of cars VW or Audi that have the 2.0t that will work in my car?
Old Jun 28, 2019 | 12:19 PM
SMac770's Avatar
Community Builder
Community Influencer
That A4 2.0T motor should be a CHHB motor. The normal selection to replace a B8.0 CAEB would be a B8.5 CAEB/CAED/CPMA/CPMB.
The internals seems like they would be the same, but you'll be swapping over all the external parts like intake manifold, turbo, accessory bracket, etc. Seems like you might have to also swap over the oil pan and something called oil pickup.
So I imagine it could be used as a replacement for the core block/head of a CAEB, but you'll be swapping over more non-core parts than you would otherwise.
That said, one other area that some quick looking seemed to imply a possible difference is the end of the crankshaft. Obviously, you'll be swapping over the clutch and flywheel or whatever. If you have an automatic, then you wouldn't have a needle bearing and so maybe any issue with the needle bearing seat would be irrelevant.
But these are the areas of concern that seem to pop up with a quick google search.
ehale
2.0T FSI Discussion
Jun 28, 2019 02:07 AM
Nitrokid
Q5/SQ5 MKI (8R) Discussion
May 13, 2018 02:19 PM
AEGA4
Mar 17, 2003 07:19 PM
drhaller
18
Jun 19, 2002 07:01 AM
tranbert
Apr 17, 2002 07:41 PM
