19” tire pressure?
Car Tire Pressure
A4 with the 2.0L 4-cyl. Gasoline Engine with:
225/50 R17 94H All-season Tires:
Normal load (F/R psi): 30/28
Max. Load (F/R psi): 35/35
245/40 R18 93Y High-performance Tires:
Max. Load (F/R psi): 33/33
245/40 R18 97H All-Season Tires:
Normal load (F/R psi): 35/32
Max. Load (F/R psi): 36/36
245/35 R19 93Y High Performance Tires:
Normal load (F/R psi): 36/33
Max. Load (F/R psi): 41/44
Car Tire Pressure
I have 245/35 R19 Continental...
The car is not 50/50 balanced. More weight on the axle requires more tire pressure for the same contact patch. Audi's document for the 8W "45" with 18" or 19":
partial load (two adults in front) - 36 front / 33 rear for normal tires or 41 front / 38 rear for "ECO" tires
full load (five adults and full trunk load) - 41 front / 44 rear
wow, those are up there, more than the pressures on my B8.0 2.0T avant.
As for wear, you rotate tires every 5k for a reason.
Actually it's for a full load of passengers, a full load of luggage in the trunk and for sustained high speed driving on the highway. Basically it's for long distance trips. Under those conditions the tires generate a lot of heat. Higher tire pressure dissipates heat better than lower pressure so the tires don't fail from overheating.
Void20 (05-10-2021)
Samsdad
Want To Buy - Archive (NO NEW POSTS HERE)
04-01-2019 06:56 AM
