2017 A4 coding tweaks
#1001
Managed to get traffic sign recognition to work after months of work, as previously said you need VCP to get this working but I used ODBeleven to do the rest.
Tested it on UK road signs all works fine.
Getting the flash coding for cameras and country is a nightmare.
https://flic.kr/p/21BCVp1
May I ask where you sourced the flash coding for? Also did you use your own VCP or take it somewhere for it to be flashed?
I have just OBDEleven at the moment and would like to add this feature if possible.
Cheers
#1002
I'm also in the UK so any pointers would be very welcome. Thanks.
#1003
Does it show up in the hud as well?
Instructions would be greatly appreciated!
#1004
I think you can code the HUD but i dont have it on my car so not looked into coding, I have a pre loded dongle that i got from Germany for £170 it can flash the camera and install the coding for TSR I dont know if the mmi part is included as i already had my car coded with odbeleven and used the dongle after coding.
i used this coding for mmi
- 17 Instruments, Long Coding, Byte 05, Bit 2 on
- 8E Image Processing, Long Coding, Byte 02, Bit 0 on
- MMI Hidden Menu: car/cardevicelist, VZE on
- MMI Hidden Menu: car/carmenuoperation, VZE => 5
The link for dongle is https://www.kufatec.de/shop/de/diagn...ennung-vze-mlb
If anyone wants to meet up i can code your car with my dongle for a small donation save shelling out on £170 with postage.
#1005
That will not work. The dongle can only be used on one vehicle. I suspect your vehicle's VIN is recorded by the dongle during the flashing process. It can be used multiple times on the same vehicle though.
#1006
This is the coding i used with OBDeleven
STG 5F (Informationselektrik)
STG adaptationVehicle function list
Select BAP-traffic_sign_recognition_0x21 -> adjust value to active
Select Vehicle menu Operation-menu_display_road_sign_identification -> Adjust value to enabled
Select Vehicle Menu Operation-menu_display_road_sign_identification_over_thresho ld_high -> adjust value to enabled
STG A5 (front / camera)
STG access authorizationEnter release code 20103
STG Long Coding
Byte 1 -> enable bit 0
Note: With newer cameras, this applies instead: Byte 16 -> Bit 4 (with the current VCDS the bit is labeled)
This is the VCP coding that i could not understand or use
In the following the necessary codes to activate the traffic sign recognition, if a front camera as well as the MMI navigation (goes with MMI navigation and with MMI navigation plus MMI touch) is installed. As a first step, the camera must be parameterized, otherwise it can not be coded.
Coding requires VCP for the parameterization of the camera!
Stand 14.03.2017: The parameterization / Flash file of the camera is sometimes only available for index A (8W0907217A)
Stand 25.04.2017: The parameterization / Flash file of the camera is now also available for index B (8W0907217B)
Stand 26.06.2017: The parameterization / Flash file of the camera is now also available for index C (8W0907217C)
#1007
#1008
#1010
The dongle also can fully code on its own but not sure if it codes the mmi options as mine had been coded with OBDeleven before I used the dongle.
just wondering if anyone knows if fitting new indicator stalk module with the lane assist button to my car will work without coding so I can switch it on and off?
