2017 A4 coding tweaks
#1011
I think you can code the HUD but i dont have it on my car so not looked into coding, I have a pre loded dongle that i got from Germany for £170 it can flash the camera and install the coding for TSR I dont know if the mmi part is included as i already had my car coded with odbeleven and used the dongle after coding.
i used this coding for mmi
- 17 Instruments, Long Coding, Byte 05, Bit 2 on
- 8E Image Processing, Long Coding, Byte 02, Bit 0 on
- MMI Hidden Menu: car/cardevicelist, VZE on
- MMI Hidden Menu: car/carmenuoperation, VZE => 5
The link for dongle is https://www.kufatec.de/shop/de/diagn...ennung-vze-mlb
If anyone wants to meet up i can code your car with my dongle for a small donation save shelling out on £170 with postage.
#1012
Thanks for that, really useful. I've ordered the dongle from the Kufatec UK site so it was £160 delivered. I haven't done the MMI coding so will report back and let you know if it's necessary or whether the dongle does everything. There are no downloadable instructions so hopefully some come with the dongle.
just don’t panic at all the warning messages that flash up as it’s doing it’s stuff, I thought I had killed my car 😃
#1013
That’s good, let us know if it codes the mmi if not I’ll dig out the coding I used with OBDeleven, the instructions I got from kufatec were sit in car all doors bonnet boot shut, ignition on for one minute then plug dongle into ODB red light on when it goes green your done.
#1015
hello,
i have a 2017 audi a4 built in march of 2016, I have front parking sensors that come on if i push the parking button on dash.. I bought the obdeleven and tried to long code it to have the parking assist enable auto.. However after following the steps it still isn't showing up in the parking assist screen.. only to change the volume still.. am i missing something here.. thank you
#1016
hello,
09/Central Elec Long Coding Automatic PDC front Byte 37 / Bit 1 on
Keep in mind that this will activate the front sensors when you get close to an object ahead of you. You need to be within about 3 feet. You will not get the full parking screen. You will only get a small overlay on top of whatever is displayed on the MMI screen with graphic representation of the front sensors. At first you only get the graphic. As you get a bit closer, you should get the audio warning tones.
#1018
On the contrary, you have to be very close before it comes on. Closer than most anyone would normally be when stopped at a red light. And it's very handy when you want to snug up the gap... just pull forward until the graphic comes on and stop before the annoying beeping starts.
#1019
Is this what you did?
i was under the impression when i go into drive assistant>parking aid> i would see a box to enable auto parking sensors. however i do not.. I just see 3 boxes for volume control of the sensors when pulling in. When pulling into the garage i don't get any warnings unless i physically push the parking button on the center console. then half the screen comes up and i can see how close i am and i hear beeps. so i'm not sure what i'm doing wrong to get the parking sensors to trigger on auto without me having to push the button.. My wife has a b9 built in june of 2016 and she has the auto function..
#1020
yes i followed all the steps on page 1..
Did you check that the bit really did get set? If I recall, you have to hold the checkmark button until it tells you the coding was accepted.
