2017 A4 coding tweaks
#731
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
#732
I tryied to enter the MODULE 76- Parking Aid to activate it, but without sucess. I think our car doesn't have this module.
Tryied to activate the visual parking aid, on the central eletric module, but, again, nothing happened.
I'm using obdeleven.
Can someone help us?
#733
Same problem here.
In VWs, you need to change the module to get a visual indicator for cars that come only with the beep. It might be the same for Audi too.
#734
I did it a while back and forgot where I found it online. But I remember the coding for amber side marker is the same as the B8.5. give this a try and see if this works.
Central Electric 09
Coding
sidemarker_via_lcm
From ACTIVE change to NOT_ACTIVE
https://www.audiworld.com/forums/a4-.../#post24934141
#735
Tried this one with no luck, but went ahead and found how to do it without long coding.
Central Electric 09
Coding
sidemarker_via_lcm
Central Electric 09
Coding
sidemarker_via_lcm
#736
The visual indicator only comes on a higher trim level, with reversing camera (not my case).
When I used, for the first time, the obdeleven, the 76- Parking Aid module was not there. I enable it, but coudn't enter (problaby because the hardware was not installed).
On the module 5f- control unit, on adaptation, there was an option called "OPS_DIsplay_in_dash_board_display_unit". I changed it to "active", but nothing happened.
On the UK, there is a Option, called "Parking System Plus" as a £395 extra on all models, that enable the visual parking aid (i think they put it as standard on 17/17 models).
A friend told me that the new A3, on the basic trim, has the same issue. Only beeps.
On time, my car doesn't have parking sensor on the front.
#739
I'm im Brazil.
#740
