2017 A4 coding tweaks
#951
This is outstanding!!!! Very nice Sir.
Can anyone offer some more instruction on how to do this?
Combine the park assist 360 camera view with the OPS (Optical Parking Sensors) In the display
(not sure how this actually can be coded - different opinions)
2. ORIGINAL - UDS Adaptation Channel: IDE01170-Visual display for park assist
Stored value with OPS display
2. MOD - UDS Adaptation Channel: IDE01170-Visual display for park assist
Stored value with OPS 360°
#953
Does anyone know if this actually works:
Disable automatic reset for the auto high beam assist
Unit 9
Access 31347
Adaption
find in the menu "channel 5 assistance light functions-Fernlichtassistent reset"
Change to not active
Now everytime we turn off the car and then on, the high beam assist will remain active
sometime can happen that the car reset the control anyway but the symbol auto is still on
Unit 9
Access 31347
Adaption
#954
Not sure if this can be fixed with coding. There is a thread in the A5 board about how the top view 360 camera view won't stay selected. I'm having the same issue with my A4 Prestige. This is apparently a known defect by Audi. So if you can figure out how to make this setting stick with coding changes that would be amazing.
#956
So I can't get the fog lights to stay on with high beams. Worked great on my B8 and B7, but not anymore. In OBD11, the setting is there, but even when I set it to inactive, the fog lights still cut out when I turn on the high beams. Any suggestion what the other missing trick would be?
#958
Turn turning stalk to left - left parking light comes on. Similarly with right. In Europe it's frequent that cars park with just half the car width in the street. This lighting has its root back in the day when you had normal light bulbs so half the battery drain was a good thing. Also, if a car has only one side light on it's pretty clear that it's parked, while with two lights it may be just stopped.
Andrew C. (12-30-2021)
#959
Has anyone with a prestige model been able to see active lane assist in the HUD? I have coded it as directed in previous posts but the ALA is only in VC and not in the HUD. As it stands the HUD is fairly useless unless you have navigation going without the Driver Assistance Package bc it only shows current speed.
still hoping someone will figure out vze traffic signs.
#960
