2018 map update seems out
#11
you have a premium plus, so there should be two sd card slots in the glove box in the DVD player. You should check those out, they are really useful for storing music or books. Anyway, when you update, put the sd card in, go to Audi Connect on the MMI, choose software update, choose the appropriate sd card slot and off you go,
#17
#18
OK...just went out and the MMI does give the opportunity to install through USB. I put both the Mib1 and Mib2 folders onto the USB stick. However, it will not allow me to select the USB as it remains grayed out. Am I loading everything I need onto the USB or am I supposed to do something more before attempting an update? Shouldn't be any different for an SD card versus a USB.
Anyone whose done it have any insight please?
Thanks !
Thanks !
#19
In case anyone is confused about where to check for and obtain Map updates, you should be logging in to https://my.audi.com (and choose local portal if it's offered). You may have to register with your VIN if not previously registered.
Then click on "Audi connect services" under the rendering of your vehicle, and scroll through the items until you see "Map update".
You won't find it at https://myaudiconnect.com
#20
In addition to my post #18 above, can someone take a screen shot of the latest version number that's associated with this update or just type it into a reply? Thank you
