2018 map update seems out - Page 3 - AudiWorld Forums
Go Back  AudiWorld Forums > Audi Models > Audi A4 > A4 (B9 Platform) Discussion
Reload this Page > 2018 map update seems out
Sponsored by:
Sponsored by:
Old 11-14-2017, 10:21 AM
  #21
gguy's Avatar
Originally Posted by securityguy View Post
OK...just went out and the MMI does give the opportunity to install through USB. I put both the Mib1 and Mib2 folders onto the USB stick. However, it will not allow me to select the USB as it remains grayed out. Am I loading everything I need onto the USB or am I supposed to do something more before attempting an update? Shouldn't be any different for an SD card versus a USB.
Anyone whose done it have any insight please?
Thanks !
There should be two folders on your stick (I've never done it by the stick, always used SD, but it doesn't matter), and two files. It should have:
Files
023100C.md5
metainfo.txt (you don't really need this one, it just unzips with the package.
Folders
Mib1
Mib2
The md5 file, as I understand it, is the executable for the MMI.
As far as version, mine just says 2018 version now.
gguy is offline
Old 11-14-2017, 10:36 AM
  #22
securityguy's Avatar
Thanks! So I have the two folders and the md5 file and still nothing. It is not recognizing any available updates from the usb. Canít imagine that an SD card will make any difference.
securityguy is offline
Old 11-14-2017, 10:52 AM
  #23
gguy's Avatar
It may be. There was a thread on this for the last update and I ďthinkĒ that I remember something about that but Iím not sure. You may be able to find that thread.
gguy is offline
Old 11-14-2017, 12:08 PM
  #24
gguy's Avatar
I also remember something about the device having to be formatted with Fat32, but that may have been my Garmin rather than the Audi.
gguy is offline
Old 11-14-2017, 01:39 PM
  #25
The USB is formatted in FAT32 already. I ordered a 32GB HS SD card from Amazon. I'll try that but will use it for music regardless when I am done. I just can't imagine why the USB will not work as it shouldn't matter the media used to do the update since it gives you a choice in the MMI menu. Any additional thoughts/recommendations are welcome.
Old 11-14-2017, 01:40 PM
  #26
Dan in St. Louis's Avatar
Originally Posted by ropuff View Post
In case anyone is confused about where to check for and obtain Map updates, you should be logging in to https://my.audi.com (and choose local portal if it's offered). You may have to register with your VIN if not previously registered.
Then click on "Audi connect services" under the rendering of your vehicle, and scroll through the items until you see "Map update".
You won't find it at https://myaudiconnect.com
And BTW don't believe the stated download speeds. My Windows Task Manager is charting about 32Mbps (Mega bits/second), which would be about 8 MBps (Mega Bytes/second). The MyAudi Download Client is claiming 23 Mega Bytes/second.
If you are unable to obtain this update directly from Audi, send me a private message.
Dan in St. Louis is offline
Old 11-14-2017, 05:20 PM
  #27
anfnj22's Avatar
Originally Posted by VM View Post
I think it's probably the other way around, i.e. my Java (or something else) is too new. I'll go troubleshooting it later... *sigh*
Mine was doing the same thing, I down graded to Java 8 and it downloaded without problem.
anfnj22 is offline
Old 11-14-2017, 05:36 PM
  #28
VM
Mine decided to work today without me doing anything wrong. Maybe a server it was trying to connect to was unhappy yesterday.
I just finished downloading the map update now. It was strangely fast compared to the previous times...
VM is offline
Old 11-14-2017, 06:02 PM
  #29
NorthwestB9's Avatar
Does Audi allow unlimited updates when downloading the maps from MyAudi? Or is there a fixed number of updates you can do for free? That's the only thing keeping me from jumping on this update.
NorthwestB9 is offline
Old 11-14-2017, 06:05 PM
  #30
I think I read somewhere that you get 5 updates and they come out every 6 months. Someone can correct me if I am wrong.
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
