265/35r20 on A4 B9? would it fit?
My friend is trying to sell me a set of 265/35r20 from his A7 as he is upgrading to 21" , would they fit okay on the a4? or would I need spacer?
You definitely would not want to run a spacer assuming you're talking about the 20x9 et37 A7 wheels. Anything lower than et37 with a 265 tire will be close to touching on the fender. Should be fine on the inside. If it's your buddy selling them, why not throw one (or all of them) on to test fit?
You would have to change the tyres - need a 265/30x20 tyre on a B9 A4, otherwise should be okay. The OEM B9 20" wheel is 9x20 ET35, with a 255/30 tyre. Pretty close - geometry looks okay in terms of rolling circumference, clearance, and scrub radius. On an A4, there is no concern with brake clearances.
Go here to work this stuff out yourself:
https://www.wheel-size.com/size/audi/a7/2017/
https://www.wheel-size.com/size/audi/a4/2018/
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
Clixt (11-29-2020)
Ah, yes. I missed 35 in the tire size he mentioned. Somewhere in another thread he mentioned he's on the non-sport suspension so the 35's may actually fit, but they're going to make the car even taller. It'll also throw off the speedometer by about 3.8%.
I would also consider pot holes in your area. I know as soon as I put my 19s back on for the summer the ride comfort is going down a bit. I would never put 20s knowing some of the potholes and road ondulations in Toronto.
So, I have a unique one for you guys...
Any chance a 245/65/17 would fit under an Allroad? I'm currently lowered 2.2in on 245/35/20s with no rubbing. The difference in tire diameter is 2.7 but only half of that will be up correct? The difference in sidewall is 2.89in but the wheel is 3in smaller. Width is the same... I'm thinking the only concern would be the front and back of the fenders. Am I missing something? I did find a company that makes spacers if I wanted to go up another .5-1in.
This site is great at comparing two sizes. Does all the math for you...
https://www.tacomaworld.com/tirecalc
