A4 B9 rear boot problem
hi
I cannot open my rear boot manually by pressing the button at the rear boot but I can open the boot with the button at the driver door and also with the remote car key.
A workshop checked and mention it is the rear boot button which is faulty.
Audi checked few weeks back as well and mention it is the actuator switch which is faulty but this workshop say it is not since the boot can be open by the remote car key.
Anyone have the same problem ? Can we buy this rear boot button part online ?
regards
regards
hi
regards
regards
Let me check that later. if it is deactivated, it seems both audi and the workshop missed that.
My A4 is about 3 years 2 months, the boot lid manual open was working till my last servicing at audi in Dec 2018. I was assuming wear and tear of whatever parts.
this button is more than double the cost of the actuator switch.
thanks
thanks
I've had the same problem for about 4-5 months. It was intermittent at first, some weeks it would work then nothing. Thought something was loose or stuck with the connectors but couldn't see anything obvious. Tried everyting including looking in the car settings in case something was changed or reset. The boot would open from drivers' door switch and also from both car fobs. Just wouldn't open manually from the boot lid button at the rear of the car.
Just had my usual service and mot and asked them to check it out. They confirmed that it was the 'Boot Micro Switch' the part is costly which came to £175 + labour, doesn't take long to fit though.
Hope this helps others searching for ideas.
For me it wasn't, opening the bottom 'wirelessly' wasn't the problem. Key fob and drivers' door button worked fine. I got my micro switch replaced yesterday and now my boot button is working like it should. But you could be right for others with similar issues and is worth checking.
