Atrocious throttle response
#21
I've been stage 1 APR for a while now and want to give a bit of insight. Take it with a grain of salt as it's only one person's opinion.
I love the tune. But I didn't do it to get rid of the horrible throttle response, although it is somewhat improved. I'm of the opinion that an ECU tune almost requires a TCU tune with it (Audi designed the two to work together, and when you mess with one, you negate all of the work they did to harmonize them). With just APR, power delivery can be a little choppy and uncomfortable for passengers, but I'll admit I'm a little aggressive on the accelerator. I haven't seen a software TCU tune yet, so I ordered the Pedalbox from Chiptuning.com. It should be here early next week, and after playing around with it, I'll report back.
https://dt-power.com/product/tcu-transmission-tuner/
I ordered mine today. Can't wait to try this out.
I don't have an ECU tune, but do have a piggy back and feel the same way. I feel there are times the transmission and engine are out of sync and cause some choppy feel. Especially hitting the pedal hard and shifting at high rpms.
#22
I'm actually a fairly conservative driver and I'm usually not very aggressive on the accelerator. Have you experienced choppyness or other understandable side-effects in the more conservative operating regimes?
Thanks!
- Eric
#24
I have a 2018 A4 and while out driving today I tested the throttle response on a number of starts from a dead stop and I did not notice any lag. All trials were done in “Automatic” mode with the transmission in D, not S.
The only thing I do notice is that more throttle motion is necessary compared to my wife’s Subaru. I think that the Subaru is a little too touchy, probably to make you think you have a more powerful engine. I wonder if the later models have a different TCU/throttle map.
#25
- Eric
#26
Although I find the latency from a dead stop annoying, it's really most pronounced when on the highway at a stable speed, say 60, and you want to accelerate to say 70. Do you notice a lack of responsiveness there? I find that the only way to get the car to respond in a reasonable amount of time in such a situation is to over-correct and punch the throttle, which is a very uncomfortable way to get to 70.
- Eric
- Eric
I will post what I find next week.
#27
- Eric
- Eric
#28
Lag when cruising on the highway and then stepping on the throttle to accelerate mostly comes from the transmission deciding to downshift if you give enough throttle that it thinks you want full acceleration. As mentioned above, multi gear downshifts can be slow with the DSG. It's why I primarily drive in manual mode on the highway, unless I have ACC engaged. I do dislike the tendency of automatic transmissions in general to downshift at the slightest throttle input. Usually I just wanna accelerate in the current gear and if I need a lower gear I will downshift myself. Today's transmissions are programmed to down-speed the engine and have more and more gears. Mercedes is now up to 9 gears and some other manufacturers have 10 gear transmissions. It's all in the name of fuel economy. Turbo charged engines are gas guzzlers on boost, so to get these advertised miles per gallon, the engine needs to be kept out of boost. That's the secret behind down-speeding. The longer the engine can be kept out of boost, the better the fuel economy, so modern transmissions quickly upshift to keep rpms low, but then need to downshift multiple gears to get a decent acceleration when you step on the throttle and the turbo needs to spool up, so that leads to these kinds of lags.
#29
I think they do speed up shifts a bit, but there are mechanical constraints responsible for this. Even my RS5 with a track tuned DSG has this lag if I just blindly mash the throttle from 7th gear. Engine howls, but the car doesn't move for about a second while the transmission is busy hunting for the lowest possible gear.
#30
