Audi Beam Rings (aftermarket install?)
Old 07-26-2016, 06:47 AM
phanatic's Avatar
Default Audi Beam Rings (aftermarket install?)
I haven't ordered my car yet but I wanted to get the Audi Beam Rings door lights. The option is $250. I was wondering if anyone knew what the cost is to get the genuine part and if it's a super easy install or not. I'm not mechanically inclined so is it as simple as a couple screws and replacing a cover on the light? Thought I might try to save a few bucks and do it myself.
Old 07-26-2016, 07:00 AM
Strife1013's Avatar
Buy them yourself, you can get them on Ebay (brand new) for $156.00 Part number 4G0052133A
They are very easy to install, just need a flat head screw driver to pop out the old ones...it's plug and play.
I ordered myself one set and will order another set shortly so that I have them on all 4 doors.
Also you have two options on ring beams: Audi rings and than one that says Quattro, I like the rings better. It's a pricey upgrade by I think it will be worth it.
Check out this thread for pictures and a lot of good information:
https://www.audiworld.com/forums/q7-...later-2901854/
Also, all those extra's on the order sheet can be bought for almost half the price elsewhere. All weather mats can be bought on ECS Tuning, a USB cable can be bought on Amazon (nothing special about "Audi's USB cables), it's like a 1000% mark up, yes a thousand if not more.
Old 07-27-2016, 03:00 AM
DirkM's Avatar
If $250 is for 4 doors then it's cheaper than aftermarket. The install is easy though,, so if you can source them for $125 a pair or less, then aftermarket might safe a few bucks.
Old 07-27-2016, 04:43 AM
Strife1013's Avatar
It's $250 for one pair, I asked the dealership and verified it with a car on the lot that had it on the invoice or I would have had the port do them.
Old 07-27-2016, 04:59 AM
DirkM's Avatar
eBay.de has them for about $90 plus $30 shipping, I got mine from a seller Audi Zentrum Essen Shop, install took 10 minutes
Old 08-01-2016, 10:32 PM
oripaamoni's Avatar
Totally worth it. Was pleasantly surprised when I discover them!
Old 08-04-2016, 04:29 PM
Audi2589's Avatar
Does the A4 have regular lights if you don't have the rings/quattro logo?
Old 08-04-2016, 06:01 PM
Eric5273's Avatar
Yes
Old 10-09-2016, 05:03 PM
bengtc's Avatar
Any tips on the installation? Do you pry from the edge of the light closer to the car or the other side? I tried today and was using alot of force but they weren't budging....didn't want to use any more force...
Old 10-10-2016, 06:24 AM
mlingama's Avatar
Pry from the shorter edge. I am not even sure it would work from the longer edge at all. I bought a cheap set from Ebay first before I got a set of Audi ones from Ebay and the only thing about the ebay ones are they came with a little plastic Pry too. Don't use anything metal to pry them out.
Quick Reply: Audi Beam Rings (aftermarket install?)
