Audi Maintenance Intervals
I'm thinking about branching at from my previous Toyotas - Prius and Camry, and now trying an Audi A4. One of the things that concerns me are the maintenance and repair costs. My Camry made it ~130k miles with no repairs, and little maintenance, and the Prius to 150k miles, without one single repair. The prius was on the original brakes, and had the plugs changed at 120k miles. I think the Camry plugs were changed at 100k+ and one set of brakes around 90k. Audi maintenance schedule says plugs every 40k miles, and change brake fluid every 2 years. Why is it Toyota brake fluid can last indefinitely, and Audi cannot? And why does Audi use lousy spark plugs too?
If these costs are your primary focus, stick with an Asian car.
...The prius was on the original brakes, and had the plugs changed at 120k miles. I think the Camry plugs were changed at 100k+ and one set of brakes around 90k. Audi maintenance schedule says plugs every 40k miles, and change brake fluid every 2 years. Why is it Toyota brake fluid can last indefinitely, and Audi cannot? And why does Audi use lousy spark plugs too?
Point being that the Audi will outperform, in spades, either one of those vehicles, as it was intended to do. As such, it requires a higher level of care for the vehicle. It sounds like you came from more economy based cars, which is fine and well, but do NOT expect that out of a vehicle that will do laps around either of those cars in comfort, style, and performance.
Also, for what it's worth, brake fluid is susceptible to getting water within it, and thus, reducing its boiling point, rendering it ineffective. You outta be the judge of when to change yours based on your area. Here's an article to check out for reference. https://www.cars.com/articles/how-of...1420680336417/
I've been doing maintenance on my own cars for over 30 years and have never seen a manufacturer recommend brake pad replacement based on mileage, before they get to the recommended thickness. Can you provide a link to a mfg's maintenance schedule. (With several SCCA titles, I assure you I haven't babied my cars).
OP, if your starting opinion is that Audi makes lousy stuff and doesn't know what it's doing, "branching out" probably isn't a good option.
fwiw, Toyota brake fluid definitely can "last indefinitely", but it almost assuredly isn't up to spec after 3-4 years. The Prius schedule calls for fluids to be inspected at every 5,000 mile interval. If your professional mechanic never changed brake fluid - shame on him//her. You also seem to mixing brakes with brake fluid - two very different maintenance items.
Ok this is coming from a tech that has been working on cars for many years. Yes fluid changes are a preventive thing but if you get into a habit of changing them out every 2-3 years, then you reduce the likely hood of a component failure. What I have seen over the last 7 years of wrenching on Toyota's, is that if the customer does not change the brake fluid when it is recommended either by the maintiance book or when the tech working on the vehicle says so, it is almost impossible to get all the dirt that builds up in the reservoir from the master cylinder seals breaking down, the fluid literally turns green. Even sucking out all of the old fluid and running new fluid through the system at that point it becomes almost pointless. At that point, replacing the master cylinder, rubber hoses and callipers/wheel cylinders is the only logical route. This is why most front callipers lock up due to lack of maintince. Highlanders and corolla's are the most prone to this but have seen that issue on the whole range except on any of the hv vehicles. So if someone is saying to replace the fluid in your ride, don't question it too much.
I understand that driving a car more aggressively would cause the brake pads to wear faster, and thus need more frequent replacement... but does more aggressive driving cause the brake fluid to degrade (absorb water?) faster? Until the 120k service, I had no maintenance done other than oil, tires, and a few filters on the Prius. The oil place checked the quantity and quality of the various fluids, and never recommended changing anything. If, hypothetically, I drove the Audi A4 like a grandmother, and like I drove my camry or prius, why would it need more maintenance than those cars? According to Beezy... "the fact that it's designed with harsh conditions in mind." If it was truly designed for harsh conditions, but wasn't driven harshly, shouldn't it need very little maintenance? One of the reasons I am looking at Audi but not BMW or Mercedes, is because Audi seems to have a better reputation from a repair or maintenance perspective than those other german cars... and I do like the way it drives as a nice change from generic white bread toyota....
Can you drive the entire life of the car without ever changing the brake fluid? Sure, absolutely, but in the time that you need to use the brakes in an emergency maneuver, the biting point where the brakes would engage is elongated as water is compressible; hydraulic fluid is not. You also run the risk of causing corrosion in your brake hardware. It's a lose-lose situation.
Very few Prius (Prii?) probably ever have their brake fluid boil just due to the way they are typically driven. However in my opinion many more A4 and especially S4 would encounter this problem. Water when converted to steam expands 1700 times the volume of its liquid state and this forces brake fluid back towards the brake fluid reservoir and away from the area it is needed most, directly behind the piston pushing on the super heated brke pad, and so even the tiniest amount of water behind the piston will cause serious problems in braking efficiency. Additionally the resulting rust will wreak havoc on the brake system and the ABS system.
i change brake fluid every two years in all my vehicles, transmission fluid and coolant at 75% of manufacturers recommendations.
Have you actually driven an A4 you're interested in yet?
I've had my B9 A4 for about 14 months now, and I still have fun when I punch it, and it's only an A4, not an S4 or RS4! I could only imagine how much more fun they are! It's definitely designed more towards the performance/technology aspect, but that's the price you pay to play.
The engine and transmission are great, I think you really need to drive one if you haven't already before you worry about the costs of ownership and decide if the increase in performance/technology is worth the increase in cost.
arf1410, my advice to you is to get a Lexus. From what I see, you don’t need performance while prefer to have luxury and low maintenance. A Lexus is perfectly fit your need. I am almost certain you will regret getting an Audi, or BMW or Mercedes.
