AZE in HUD A4 B9
AZE in HUD A4 B9
Hello,
I'm a new member and I have coded traffic sign recognition in my A4 B9 with VAG CAN PRO and it's working perfect, I can't find anywhere the coding for getting it showing in the HUD.
Thanks in advance for your help
Thanks
How did you code it in in the first place? No HUD here, I’d just like to code in traffic sign recognition but I thought it could not be done.
Hi gguy,
You need to have VCDS from Ross-Tech or VAG CAN from VagTech or OBDEleven and of cause the front camera for Audi Pre Sense, I don't if this standard equipment in the US....
Coding:
Vehicle function list
Select BAP-traffic_sign_recognition_0x21 -> adjust value to active
Select Vehicle Menu Operation-menu_display_road_sign_identification -> Adjust value to enabled
Select Vehicle Menu Operation-menu_display_road_sign_identification_over_thresho ld_high -> adjust value to enabled
STG access authorization
Enter security code 20103
STG Long Coding
Byte 1 -> enable bit 0
Note: For newer cameras, this applies instead: Byte 16 -> Bit 4
Byte 5 --> Enable Bit 2
ENJOY !!
Coding:
STG 5F (Informationseletronics)
STG adaptationVehicle function list
STG A5 (Front/Camera)
STG Long Coding
STG 17 (dash panel insert)
STG Long CodingByte 5 --> Enable Bit 2
ENJOY !!
I'm in France...this is working in my A4 2.0 TFSI Quatro from 2016, you need the front camera in windscrren mirror (STG A5 Front Camera) this is standard equipment in Europe I don't know about US....
The US cars doesn’t seem to be able to get this work work. But I have a ROW car and keen to find out if this works. Do you mind sharing your A5 module Long code and adaptions?
Did you change byte 1 or 16?
Here you go.....
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 8W0 907 217 A HW: 8W0 907 217
Component: BVS H14 0030
Coding: 0404090200000403022023A2C50000FC00F0C020C000
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 3A70B9A9BD125C9684-806E
Here you go.....
Thanks in advance!
