Can I check tire pressure through MMI for my 2017 A4?
#11
Audi uses a TPMS system that has no clue what your tire pressures are. You tell it "my pressures are correct" by resetting the system, and it takes the relative rotation rates of the tires as "correct". Audi assumes one of the tires must be low if there's a difference in rotation between two wheels on the same axle. It's a **** poor, but legally sufficient, system.
I'm looking to pick this up at some time to put on the car and see how it goes:
#12
https://www.amazon.com/B-Qtech-Press...f=pd_sbs_263_2
Indirect TPMS is more than sufficient for the average driver. For the average driver, the measured tire pressure is only meaningful while the tire is cold, so the readings from direct TPMS is only useful for a brief moment before the tires start to heat up. Once the tires are warm, the numbers are useless. Unless, you track the car. On a track you may wanna monitor the hot tire pressure and adjust it and also monitor the temperature of each tire. That's why Audi is now starting to offer optional direct TPMS on their RS models and the R8. Total overkill for an A4, though.
#13
It's still guesswork instead of directly measuring reality. Even the wiki page makes clear that it's guessing there's an issue when inputs differ from the recorded first bit of driving after a reset (for second gen). I prefer factual data when it comes to safety topics.
When my blipped and I checked my tires, the left rear was down from 34 to 25. Then another time I checked and it was 28 but no light. 28 is too low. 25 is way too low. The tolerance on the system is too slack. But it's a 2009. Seems that was a time of change in the system Audi was using.
And the numbers are useful if you're filling up your tire. My nephew has a slow leak in one tire on his Camaro. He just turns on the dash and hooks up a pump. Stops when the dash says the tire is at the desired pressure. If GM can do it, Audi can do it. This is not an economy brand.
#14
#15
On a positive note, with Audi's TPMS system, you don't have individual sensors in each tire, so much less hassle swapping tires/wheels.
Manual_Trans (09-01-2019)
#16
Does anyone remember the Nissan commercials from a few years back where the car would honk once you reached the right pressure? If they could do that in an Altima or Rogue or whatever that was, there's no reason a car that costs twice as much can't do it too.
Not to mention, having had it go off on me once, it would have been nice to have gotten some indication as to what was going on instead of just a generic tire pressure low warning that didn't even identify the problematic tire.
#17
And that's the only excuse/advantage for this system.
#18
Audi tpms is the best for places where you have to put Winter tires. I have a friend who has an Honda CRV and he needs to go to the dealership every six months go have the tpms reprogrammed for his second set of tires. Most people do not bother with this and drive all Winter with the tpms warning light on.
#19
#20
Was getting a tire leak fixed today. Asked the guy about TMPS since I notice I paid $32 for TPMS service kit when I get new tires. He said the newer cars don't have the sensors on the wheels so there is no TPMS kit or cost. So another cost reduction victory for the new method.
