Go Back  AudiWorld Forums > Audi Models > Audi A4 > A4 (B9 Platform) Discussion
Reload this Page >
Changing NAR Radio frequency to EU - solution
Old 05-21-2018, 04:23 AM
Default Changing NAR Radio frequency to EU - solution
If someone need to change NAR radio frequency to EU (step of radio frequency from 0.2 to 0.1) just change in block 5F - Byte 9 - change 22 to 11 manually or uncheck bite 1 and 5, check bite 0 and 4
Thant's all
sergey307 is offline
Old 05-22-2018, 06:45 AM
Thant's all
This is very useful for anyone relocating to EU from the States. Thanks for sharing.
tascon is offline
Old 05-23-2018, 12:17 AM
You are welcome
Old 05-23-2018, 10:36 PM
I have found one additional thing for EU adaptation (from NAR) - if you have virtual cockpit and change it to km per hour you will have both miles and kilometers in digital speedometer - solution is to uncheck bit 2 in byte 6, module 17 and you will have only km/h
17 Instruments - Byte 6 - bit 2 (from 1 to 0)
Old 12-21-2018, 08:24 AM
Thanks a million. In Europe you're missing all stations that end at odd numbers, if you use the NAR settings.
If somebody is wondering how this looks in OBD11, here it is:
svgenov is offline
Old 02-18-2019, 09:36 PM
Are tou using only snart phone to do that? 😳
Ege Vilcinskas is offline
Old 02-18-2019, 11:30 PM
smartphone with OBDeleven dongle
Old 05-25-2019, 07:11 AM
Default Any ideas to do with VCDS?
Did anyone knows how to do that with VCDS? Audi RS5 2015. MMI with 2G. Thanks
Old 05-25-2019, 07:12 AM
You don't know how and where i can find in VCDS?
Old 05-25-2019, 08:58 AM
The info is in sergey's first post in this thread. (The '22' to '11' is in Hex-format but he also explains the bits to set and clear.)
audi8k is online now
Quick Reply: Changing NAR Radio frequency to EU - solution
