Clean Dash Cam Install?
#21
There is a previous thread for DIY dash cam installations. If you want, check out my post for my dash cam installation, tapping off the mirror power. Maybe that will help. I actually used a radar dectector cord with taps. I used the connector right above the mirror, as opposed to using the wires on the right. I swiveled the connector down a bit and tapped into the yellow and brown. Took a while the get the taps in. I think the trick was to go behind the wire in the connector. Originally I was trying to go in front and slide the tap in. But it may be different for you.
Hopefully this is the correct link. It's post 16 in the thread, and there are pictures.
https://www.audiworld.com/forums/a4-...2903447/page2/
Hope it helps.
Hope it helps.
#22
F770 from blackboxmycar, I paid last year a lot more then currently is $260, until I wait for package to arrive I did some research on youtube and install them myself.
Te trickiest part was finding the fuses below the left foot pad to stay on safe side maybe two hours max with a brake for coffee and beer .
Spent some time exploring the app, also found a better third party PC program instead of the stock Thinkware.
any idea which fuse to use?
#24
#25
Computer scientist
Q5/SQ5 MKII Discussion
03-19-2018 11:28 PM
