Coding for heated seat adjustments.
I have OBD11 and cannot find any adaptations for Heated Seat Adjustments, can anyone help? Also, is there any coding to increase the Lumbar Support
There is an app already in OBD11 to adjust the temperature.
There are actually 3 apps now that I remember to adjust the temperature of the 3 heat stages.
Adaptation settings ("seat heater, micro adjust") in Module 09 - Central Electrics. My final settings are: Stage 1: +5 °C Stage 2: +5 °C Stage 3: +4 °C. Alternatively use the three included 1-click mini-apps (10 credits each) contained within the OBDeleven app.
Originally Posted by caranddriver
(Post 25232789)
Is there something similar for steering wheel heating? I'd love to be able to make my wheel's heat stronger because it's pretty weak.
There is an adaptation channel in the Steering wheel module for it.
Originally Posted by bruce_miranda
(Post 25233706)
(Post 25233706)
heated seat failure
Hello, I don't know if it is a right place but according to this thread after some coding with my A4 b9 (with almost all features available in stock) I have lost the heated seats in front 😰.
When I press the heat button, 3 led are ON and after 1sek goes OFF. Same for both seats (L/R). Ventilation works fine. Back seats heat works fine as well. I don't know when and what (coding) was the cause of that. Do anyone have any idea where to look? What could goes wrong? OBDeleven does not have Gataway for 06 controller that have Seat parameters to do a full scan 😔 as I was told by other users form Facebook VCDS group. What I have done with OBDeleven: Enable ACC default distance in MMI DRL (Daytime Running Lights) On/Off Option in MMI Google Earth without Audi Connect subscription Enable ability to Rip CD's to MMI "Jukebox" Enable Laptimer shown in VC Enable Needle Sweep (not so impressive with VC) Parking Assist Camera - Turn Off Speed 20km/h De-Activation of Start-Stop via A/C Combine the park assist 360 camera view with the OPS In the display things that was already in stock: Gear selection (D1,2,3.. or S1,2... shown in VC) Automatic PDC Front Enable & Pair a Second Phone via Bluetooth simultaneously Turn off range limiter for Comfort Window System Right mirror drop on reverse |
