Coding for heated seat adjustments.
I have OBD11 and cannot find any adaptations for Heated Seat Adjustments, can anyone help? Also, is there any coding to increase the Lumbar Support
Adaptation settings ("seat heater, micro adjust") in Module 09 - Central Electrics. My final settings are: Stage 1: +5 °C Stage 2: +5 °C Stage 3: +4 °C. Alternatively use the three included 1-click mini-apps (10 credits each) contained within the OBDeleven app.
Thanks for the reply, couldn't find the right module.
heated seat failure
Hello, I don't know if it is a right place but according to this thread after some coding with my A4 b9 (with almost all features available in stock) I have lost the heated seats in front 😰.
When I press the heat button, 3 led are ON and after 1sek goes OFF. Same for both seats (L/R). Ventilation works fine. Back seats heat works fine as well.
I don't know when and what (coding) was the cause of that.
Do anyone have any idea where to look?
What could goes wrong?
OBDeleven does not have Gataway for 06 controller that have Seat parameters to do a full scan 😔 as I was told by other users form Facebook VCDS group.
What I have done with OBDeleven:
Enable ACC default distance in MMI
DRL (Daytime Running Lights) On/Off Option in MMI
Google Earth without Audi Connect subscription
Enable ability to Rip CD's to MMI "Jukebox"
Enable Laptimer shown in VC
Enable Needle Sweep (not so impressive with VC)
Parking Assist Camera - Turn Off Speed 20km/h
De-Activation of Start-Stop via A/C
Combine the park assist 360 camera view with the OPS In the display
things that was already in stock:
Gear selection (D1,2,3.. or S1,2... shown in VC)
Automatic PDC Front
Enable & Pair a Second Phone via Bluetooth simultaneously
Turn off range limiter for Comfort Window System
Right mirror drop on reverse
Automatic PDC Front
