Go Back  AudiWorld Forums > Audi Models > Audi A4 > A4 (B9 Platform) Discussion
Reload this Page >
Coding for turning on Audi Active Lane Assist (all cars with pre sense)
Old 10-12-2016, 12:10 PM
Mitchfin's Avatar
Default Coding for turning on Audi Active Lane Assist (all cars with pre sense)
Here is the coding and adaptations that I used to activate Audi Active Lane Assist, I am not making any promises or assuming responsibility, code at your own risk, But it worked perfectly for me. I do get a few faults but I think it is due to me trying to activate Traffic Sign Recognition. UPDATE: Unchecking the option for STA in A5 coding (Byte 16->Bit 5) and you will no longer get the congestion assist fault code.
You will get a few bings from your car about Pre Sense Malfunction, these will all go away once you are done. This will activate the self steering, steering wheel vibration, and lane crossing warning. Do all the coding then do adaptations.
If using OBDEleven use all the directions only on the left half of the "|" symbol, if using VCDS use all the directions on the right side of the "|".
UPDATE:
Security codes:
A5- 20103
ALL Coding:
A5 - Frt Sens. Drv. Assist
HC>Active | Byte 16>Bit 7
EFP>Active | Byte 12>Bit 3
17 - Dash Board EDIT:
Lane Assistant>Active | Byte 4>Bit 6
Lane Change Assistant>Active | Byte 5>Bit 3 - This should only be on if you have Audi Side Assist (blind spot monitor).
09 - Central Electrics
Heading Control Config>heading_control | Byte 35>Bit 0
44 - Steering Assistance
Heading Control Assistant>Active | Byte 2>Bit 7
ALL ADAPTATIONS:
5F - Information Electronics
Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning = Set Value to “Activated”
Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning_over_threshold_high = Set Value to “Activated”
Car_Function_List_BAP_Gen2>LDW_HCA_0x19> Set Value to “Activated”
Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus> Set Value to “Terminal 15”
BAP Personalization = Set Value to “Not Activated”
Personalization of lane dept. warning Cl. 15 on = Set value to “Last Setting”
System mode, lane depart. warn, = Set Value to “Selection via menu”
Switch-on condition, lane depart. warn. = Set value to “On” (I had to toggle this as this is the final step that I believe mimics pressing the button to actually activate it. You know it was successful when the Lane markings show up in the VC)
You can tweak the vibration intensity, warning time, and steering effort in these A5 adaptations:
UPDATE
Directional stabilization assist driver inact deactiv threshold (3 options)
Directional stab. assist.: intensity: steering wheel vibration (3 options)
Directional stab. assist.: intensity: power steering support (3 options)
Mitchfin is offline
Old 10-12-2016, 12:44 PM
Is there a beginners guide to getting started with coding. What hardware/equipment is needed and if done on a leased car, is there a way to default all settings afterwards. Thanks!
eiskafee is offline
Old 10-12-2016, 12:47 PM
Mitchfin's Avatar
I did this all with OBDEleven which is $60 and a $20 android phone, its mostly really straightforward but there are some articles you should read, (Saving an auto scan and Channel maps [not yet available on OBDeleven]) the more expensive and more comprehensive option is VCDS and they have a great support system and articles to help you learn it.
Mitchfin is offline
Old 10-12-2016, 01:17 PM
Wuplur's Avatar
Any idea what the login code is inorder to change the A5 adaptations?
Wuplur is offline
Old 10-12-2016, 01:24 PM
Mitchfin's Avatar
Sorry. I believe it's 20103
Mitchfin is offline
Old 10-12-2016, 01:37 PM
This is awesome, thanks! I will try this on our Q7 tonight and report back.
GDawgA4 is offline
Old 10-12-2016, 02:21 PM
Wuplur's Avatar
It's accepting the login code but it won't read or allow me to change any of the A5 adaptations. Any thoughts? I'm using the factory tool and also tried VCDS
Wuplur is offline
Old 10-12-2016, 02:31 PM
Wuplur's Avatar
Figured it out! I did the initial A5 coding through the word description rather then the bits. Went back in to check the bits and they were not set. Recoded A5 and now I'm able to set the adaptations! Presense fault is no longer in the cluster. Now for the test drive!
Wuplur is offline
Old 10-12-2016, 02:45 PM
Default Nice!
Thats awesome! Good work.
ALL Coding:
STA>Active | Byte 16>Bit 5
17 - Dash Board (One of these may already be on, make sure both are)
ALL ADAPTATIONS:
You can tweak the vibration intensity, warning time, and steering effort in the A5 adaptations.
MeehowTT is offline
Old 10-12-2016, 03:04 PM
Wuplur's Avatar
Are you kidding me, you're freakin awesome! Worked like a charm! It also added the menu in the mmi to turn vibration on/off and steering correction early/late. I wonder if this will work on my wife's 17 A4. She doesn't have VC but the A5 module is standard.
Wuplur is offline
