Coding for turning on Audi Active Lane Assist (all cars with pre sense)
#501
#502
Here is the coding and adaptations that I used to activate Audi Active Lane Assist, I am not making any promises or assuming responsibility, code at your own risk, But it worked perfectly for me. I do get a few faults but I think it is due to me trying to activate Traffic Sign Recognition. UPDATE: Unchecking the option for STA in A5 coding (Byte 16->Bit 5) and you will no longer get the congestion assist fault code.
You will get a few bings from your car about Pre Sense Malfunction, these will all go away once you are done. This will activate the self steering, steering wheel vibration, and lane crossing warning. Do all the coding then do adaptations.
If using OBDEleven use all the directions only on the left half of the "|" symbol, if using VCDS use all the directions on the right side of the "|".
UPDATE:
Security codes:
A5- 20103
ALL Coding:
A5 - Frt Sens. Drv. Assist
HC>Active | Byte 16>Bit 7
EFP>Active | Byte 12>Bit 3
17 - Dash Board EDIT:
Lane Assistant>Active | Byte 4>Bit 6
Lane Change Assistant>Active | Byte 5>Bit 3 - This should only be on if you have Audi Side Assist (blind spot monitor).
09 - Central Electrics
Heading Control Config>heading_control | Byte 35>Bit 0
44 - Steering Assistance
Heading Control Assistant>Active | Byte 2>Bit 7
ALL ADAPTATIONS:
5F - Information Electronics
Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning = Set Value to “Activated”
Car_Function_Adaptations_Gen2>menu_display_Lane_De parture_Warning_over_threshold_high = Set Value to “Activated”
Car_Function_List_BAP_Gen2>LDW_HCA_0x19> Set Value to “Activated”
Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus> Set Value to “Terminal 15”
BAP Personalization = Set Value to “Not Activated”
Personalization of lane dept. warning Cl. 15 on = Set value to “Last Setting”
System mode, lane depart. warn, = Set Value to “Selection via menu”
Switch-on condition, lane depart. warn. = Set value to “On” (I had to toggle this as this is the final step that I believe mimics pressing the button to actually activate it. You know it was successful when the Lane markings show up in the VC)
You can tweak the vibration intensity, warning time, and steering effort in these A5 adaptations:
UPDATE
Directional stabilization assist driver inact deactiv threshold (3 options)
Directional stab. assist.: intensity: steering wheel vibration (3 options)
Directional stab. assist.: intensity: power steering support (3 options)
UPDATE:
Security codes:
A5- 20103
ALL Coding:
ALL ADAPTATIONS:
UPDATE
#503
I've coded this into the new Q5 just yesterday with these adaptions:
driver inact deactiv threshold = late
intensity, power steering support = weak
However, I do get the warning to take control quite often on straight roads, even though I have both hands on the wheel. I know the warning is triggered when no counter torque is applied to the wheel, but that's unfortunately pretty much impossible on a straight road.
Is there any adaptions combination that would make these warnings come on less often? And does the adaption "driver inact deactiv threshold" even make any difference? I read somewhere that the "late" option triggers the warning after 15 seconds, but it's definitely a lot faster. I mean, the way it is you must get the warning even more often when it's set to the standard "medium" settings, and I can't really imagine that.
Anyways, if anyone found a good combination or maybe another way that would be quite helpful since I have a 1500km trip ahead of me tomorrow night, right now I don't want to imagine how often the warning might come on while driving on an empty straight highway in the middle of the night.
#504
#505
Hello all, I have exactly the same problem. I have a European version with pre sense on it. I did all the coding several times with obdeleven, checked en rechecked but I cannot get it enabled. Even more, the pre sense itself is also not working any more. If anyone could assist...
#506
This is my complete log... maybe someone can see what i am doing wrong.
OBDeleven vehicle history log
Date: 2017-07-27 12:43
Car: Audi A4
Year: 2016
Body type: Avant
Engine: DEUA 110 kW (150 HP) 1.968 l
Adaptation
Control unit: A5 Front Sensors Driver Assistance System
Name: Switch-on condition, lane depart. warn.
Values:
Old value: Off
New value: On
Date: 2017-07-27 12:07
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Date: 2017-07-27 12:06
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Selection via menu
New value: On
Adaptation
Values:
Old value: On
New value: Selection via menu
Date: 2017-07-27 11:59
Adaptation
Values:
Old value: Off
New value: On
Date: 2017-07-27 11:45
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Date: 2017-07-27 11:44
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Date: 2017-07-27 11:40
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: On
New value: Off
Date: 2017-07-27 11:37
Long coding
Old value:
0404090200000403022023A08C0000FC80F0C010C020
New value:
0404090200000403022023A08C0000FCA0F0C010C020
Date: 2017-07-27 11:35
Long coding
Old value:
New value:
Adaptation
Values:
Old value: Off
New value: On
Date: 2017-07-27 11:11
Long coding
Old value:
0404090200000403022023A0840000FC80F0C010C020
New value:
Date: 2017-07-27 11:04
Long coding
Old value:
New value:
Long coding
Old value:
0404090200000403022023A0840000FC00F0C010C020
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Date: 2017-07-27 10:58
Long coding
Values:
EFP:
Old value: Coded
New value: Not_coded
HC:
Old value: Coded
Date: 2017-07-27 10:56
Adaptation
Values:
Old value: On
New value: Off
Date: 2017-07-26 15:42
Adaptation
Values:
Old value: Off
New value: On
Date: 2017-07-26 15:33
Adaptation
Values:
Old value: On
New value: Off
Date: 2017-07-26 15:31
Adaptation
Values:
Old value: Off
New value: On
Date: 2017-07-26 15:24
Adaptation
Values:
New value: Off
Long coding
Control unit: 44 Steering Assistance
Values:
Heading_control_assistant:
Old value: not active
New value: active
Date: 2017-07-26 15:20
Long coding
Values:
Old value: active
New value: not active
Long coding
Values:
New value: active
Date: 2017-07-26 14:53
Long coding
Values:
Old value: active
Long coding
Old value:
0404090200000403022023A08C0000FC80F0C010C000
New value:
Date: 2017-07-26 14:33
Long coding
Control unit: 09 Central Electrics
Old value:
80453942451800CD01450010580F00B9100331000000000000 00000000001A2000410023003000
New value:
80453942457900CD01450010580F00B9100331000000000000 00000000001A2000410023003000
Date: 2017-07-26 14:32
Long coding
Old value:
New value:
Date: 2017-07-26 10:25
App
Name: High beam assist
Old value: OFF
New value: ON
Adaptation
Values:
Old value: On
Date: 2017-07-26 10:23
Adaptation
Values:
Old value: Off
New value: On
Date: 2017-07-26 09:21
Adaptation
Values:
Old value: On
New value: Off
Long coding
Old value:
09000000008000
New value:
09008000008000
Date: 2017-07-25 22:47
Long coding
Control unit: 17 Dash Board
Old value:
04A56890288000080D0069601000000000000000
New value:
04A56890688000080D0069601000000000000000
Long coding
Old value:
80453942451800CD01450010580F00B9100331000000000000 00000000001A2000410022003000
New value:
Date: 2017-07-25 22:46
Adaptation
Values:
New value: On
Date: 2017-07-25 22:44
Adaptation
Name: BAP personalization
Values:
Old value: activated
New value: Not activated
Date: 2017-07-25 22:42
Long coding
Old value:
0404090200000403022023A0840000FC00F0C010C000
New value:
Date: 2017-07-25 22:41
Adaptation
Control unit: 5F Information Control Unit
Values:
LDW_HCA_0x19_msg_bus:
Old value: Not activated
New value: Terminal 15
LDW_HCA_0x19:
New value: activated
Adaptation
Values:
menu_display_Lane_Departure_Warning:
menu_display_Lane_Departure_Warning_over_threshold _high:
Date: 2017-07-25 22:39
Long coding
Values:
New value: active
Date: 2017-07-25 22:19
Long coding
Values:
heading_control_config:
Old value: no_heading_control
New value: heading_control
Date: 2017-07-25 22:18
Long coding
Values:
Lane change assistance:
Old value: Yes
New value: No
Date: 2017-07-25 22:14
Long coding
Values:
Old value: No
New value: Yes
Lane assistant:
Old value: No
New value: Yes
Date: 2017-07-25 22:13
Long coding
Values:
EFP:
Old value: Not_coded
New value: Coded
HC:
New value: Coded
Date: 2017-07-25 22:12
Long coding
Old value:
04A46890288000080D0069601000000000000000
New value:
Date: 2017-07-25 21:58
Long coding
Old value:
80453942551800CD01450010580F00B9100331000000000000 00000000001A2000410022003000
New value:
Date: 2017-07-25 21:57
Long coding
Old value:
New value:
Date: 2017-07-25 15:34
Long coding
Old value:
80453142551800CD01450010580F00B9100331000000000000 00000000001A2000410022003000
New value:
Long coding
Old value:
80453142551800CD01450010580E00B9100331000000000000 00000000001A2000410022003000
New value:
Date: 2017-07-25 15:25
Long coding
Old value:
New value:
Date: 2017-07-25 15:24
Long coding
Old value:
80453142451800CD01450010580E00B9100331000000000000 00000000001A2000410022003000
New value:
Date: 2017-07-25 15:23
Thanks,
J
Car: Audi A4
Year: 2016
Body type: Avant
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
New value: On
Adaptation
Values:
Old value: On
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: On
New value: Off
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Adaptation
Values:
Old value: Off
New value: On
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Values:
EFP:
Old value: Coded
HC:
Old value: Coded
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
Old value: On
New value: Off
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
New value: Off
Long coding
Values:
New value: active
Long coding
Values:
Old value: active
Long coding
Values:
New value: active
Long coding
Values:
Old value: active
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
App
Old value: OFF
New value: ON
Adaptation
Values:
Old value: On
Adaptation
Values:
Old value: Off
New value: On
Adaptation
Values:
Old value: On
New value: Off
Long coding
Old value:
09000000008000
New value:
09008000008000
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Adaptation
Values:
New value: On
Adaptation
Values:
Long coding
Old value:
New value:
Adaptation
Values:
LDW_HCA_0x19:
Adaptation
Values:
Long coding
Values:
New value: active
Long coding
Values:
Long coding
Values:
Old value: Yes
New value: No
Long coding
Values:
Old value: No
New value: Yes
Lane assistant:
Old value: No
New value: Yes
Long coding
Values:
EFP:
New value: Coded
HC:
New value: Coded
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Long coding
Old value:
New value:
Thanks,
J
#508
Remove assisted steering possible?
Is there a way to just retain steering wheel vibration and eliminate steering correction?
#509
Anyone please? I uncoded all and then redid all codings with the same lane assist error message as a result. I did the adaptions on/off several several times but nothing changes. Also engine off, reset mmi and so on. How should this be done? Thank you for helping.
J
J
