Coding for turning on Audi Active Lane Assist (all cars with pre sense)
#841
I'm wondering the same thing myself. It would seem to do the ALA coding, but then it mentioned in the description that it is for use if you have previously retrofitted the hardware for ALA. I spoke to somebody in the chat at Kufatec and they weren't really understanding my questions (though they did indicate that it was "not for my chasis."
The only item that OBDEleven cannot do is the traffic sign recognition due to the parameterization function which requires VCP.
#842
I would recommend getting OBDEleven at that price point and follow the instructions that are provided in this thread. You'll be able to do much more; diagnostics, coding, etc.
#843
Anyone here try this for getting it to read the signs?
https://www.kufatec.com/en/all-products/coding-dongle-traffic-sign-recognition-mlb-for-audi-4188
I'm tempted to get it but wondering if it's worth it (for whoever tried). Thanks
#845
https://www.kufatec.com/en/all-produ...-for-audi-4188
#846
I purchased it and it worked perfectly. It was a simple plug and play. The system recognizes most signs correctly but occasionally gets one wrong when there are 2 different limits for cars and trucks with both limits on the same post. It's a tool that helps. It displays in the HUD along with your actual speed.
#847
Pfft not working 😔😔
Hi there, i did everything as explained, got the menu in the mmi but no lane assist stripes in my virtual cockpit so no working lane assist 😔
what do you mean by the following ?
Switch-on condition, lane depart. warn. = Set value to “On” (I had to toggle this as this is the final step that I believe mimics pressing the button to actually activate it. You know it was successful when the Lane markings show up in the VC)
Thx !
Thx !
#848
Hi,
I activated the ALA and it works ! thanks a lot
I tried to activate TJA and can't make it to work (all the codings worked fine and the menu appeared in the MMI and is activated)
Do I need to buy the steering wheel lever for ALA to activate TJA ?
