Activate map display in the DIS with a small MMI
Hallo,
when I code this the navi map will be displayed in the DIS without the need for mmi+. But it is no longer possible to use the google earth view - I only have the normal map. Has anybody an idea to fix this?
STG 5F Information electronics 1
Adaptation
[VO] _Dashboard_Display_Configuration (RDID $ 0B5A)
[LO] _navigation_map_transmission_mode -> [VO] _MOST_Streaming
[LO] _navigation_map_compression_mode -> [VO] _H264
[LO] _navigation_map_Resolution -> [VO] _resolution_1
Adaptation
Hallo,
Adaptation
Adaptation
You need to use an Audi specific diagnostic tool that can access and program the different electronic control modules in the car. The most popular ones used by folks are VCDS by RossTech and OBDeleven. Many threads on this forum discussing how to use either of these tools - just do a forum search to see them.
BobT(nolonger)A6
A6 (C7 Platform) Discussion
02-18-2014 11:57 AM
BJC::wokka wokka
07-15-2005 01:15 PM
bsewall
06-03-2002 07:57 PM
