Guide: Enable Google Earth/Traffic on Canada spec Audi
I figured it would be a better idea to consolidate all the information founded by other members in one thread regarding enabling Sirius Traffic and Google Earth on a Canadian Spec Audi running the new MMI.
Canadian cars have no Audi connect features enabled from factory, we have the same hardware as the US cars, but the connected features are disabled via coding. So far, I've tried this on both my own 2017 A4 and the 2017 Facelifted A3 (Both Cdn Spec) These instructions are not official and are just provided as a mean to share findings from the forum. Make sure you do a backup of the module coding/adaptation and proceed at your own risk :) To enable Google Earth (this will require using your mobile phone's data connection as hotspot): Step 1: Set the following adaptation in module 5F (this can be done by VagCOM HEX-CAN-USB or OBDEleven) : IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts - ON IDE03471-ENG117849-Vehicle configuration-gracenote_online_other - ON IDE03471-ENG117843-Vehicle configuration-my_audi - ON IDE03471-ENG117845-Vehicle configuration-online_dictation - ON IDE03471-ENG127495-Vehicle configuration-online_media - ON IDE03471-ENG117840-Vehicle configuration-online_navigation - ON IDE03471-ENG117837-Vehicle configuration-online_POI - ON IDE03471-ENG117838-Vehicle configuration-online_POI_voice - ON IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services - ON IDE03471-ENG117841-Vehicle configuration-online_street_view - ON IDE03471-ENG117844-Vehicle configuration-picture_navi - ON IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag - NO_REGION IDE03471-ENG117836-Vehicle configuration-VZAPro - ON IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI - ON IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot - ON Step 2: Restart MMI Once you've made the above changes, RESET MMI by pushing and holding the toggle to NAV and RADIO at the same time, then press the center knob to restart While MMI restarts, turn on your mobile phone's WiFi Hotspot Step 3: Go to Settings in MMI > Connection Manager > Configure your WiFi Settings in MMI to connect to your phone's hotspot Step 4: Go to Navi/Map > Click to the 'Right' Option button > Select Map Settings Under Display > Click and Select Google Earth If you've configured a successful WiFi connection, Google Earth should load within 20secs or so https://cimg1.ibsrv.net/gimg/www.aud...13c81427e3.png Couple of Notes and Tips: - I've used Google Earth for a month now, and my data usage on my phone is around 4-500MB for my commute that is 25km one way - For Android user, I suggest downloading a paid app called 'Tasker'. Tasker allows you to automate settings based on a condition. In this case, I have my phone configured to turn on Mobile hot spot once my phone is connected to the car's bluetooth setting. This allows the MMI to connect to WiFi automatically. - MMI defaults to the standard map display after your car restarts, you will need to enable Google Earth in map display once your MMI connects to the WiFi (this takes about 30sec). - Online Search and other Audi Connect features would not work - I've tried to enable the main Audi Connect menu in the MMI (this is done by setting IDE03471-ENG117846-Vehicle configuration-remote_HMI - ON). Unfortunately, once we added the menu to the MMI main page, Google Earth would not work. I had to turn the Audi Connect menu off again to get Google Earth back. - I have no tried the SIM slot in the MMI so I am not able to confirm whether or not that would work. To enable Traffic from SiriusXM (I have not tried this, but another member has so I'll add the info here as well) Step 1: Set the following adaptation in module 5F (this can be done by VagCOM HEX-CAN-USB or OBDEleven) : IDE05111-Fee-based traffic information (TMC) - 1537 Step 2: Call Sirius Canada, provide your RadioID and get them to enable traffic subscription. Sirius traffic working in Canada: https://cimg6.ibsrv.net/gimg/www.aud...6ce07d39c1.jpg Note: - Looks like only Sirius Traffic would work. I've tried to use code 65533, 32768, 32771 (these are code for Online Traffic for the MMI) in the IDE05111-Fee-based traffic information (TMC) adaptation. They all enabled the 'Use Online Traffic' checkbox, but none of them shows any traffic information for Canada. Maybe there's another code for Canada? Good Luck guys! |
Sounds really interesting.
It was my understanding that: a) the $520 CDN option for Audi connect involved additional hardware and b) Audi Connect was required to enable Google Earth. if I'm understanding your post correctly, these coding changes would allow me to use my phone as a WiFi hotspot to provide Google Earth capability without the need for the Audi Connect option, which sounds pretty nice. Does this mean that any hardware associated with Audi Connect would already be in place in a vehicle that was not ordered with Audi Connect, or is my original understanding correct - that Audi Connect involves additional hardware, and this is simply allowing an alternative method of providing Google Earth maps? Thanks Blake |
Originally Posted by A42017
(Post 24908957)
It was my understanding that: a) the $520 CDN option for Audi connect involved additional hardware and b) Audi Connect was required to enable Google Earth. if I'm understanding your post correctly, these coding changes would allow me to use my phone as a WiFi hotspot to provide Google Earth capability without the need for the Audi Connect option, which sounds pretty nice. Does this mean that any hardware associated with Audi Connect would already be in place in a vehicle that was not ordered with Audi Connect, or is my original understanding correct - that Audi Connect involves additional hardware, and this is simply allowing an alternative method of providing Google Earth maps? Thanks Blake 1) The $520 option does require additional hardware, I believe this is the SOS, and Mobile app access part. Where you can unlock/lock your car remotely. This, I believe requires additional hardware 2) To get other Audi Connect features, such as weather/news/myAudi, I believe you need to have the integrated SIM working with a proper Audi Connect subscription. This, I believes is not available in Canada. 3) In a normal car, Audi Connect in your MMI would authenticate with the server at Audi, once authenticated, it will tap in to the built in features of the MMI which are Google Earth/Traffic/etc. In our car, we don't have the Audi Connect menu which means the authentication part is removed. Because of this, it looks like we are able to directly load Google Earth. |
Originally Posted by ekyp
(Post 24909000)
I believe there are a few parts to the Audi Connect features. I am no expert, just my thoughts based on all the information gathered. lol
1) The $520 option does require additional hardware, I believe this is the SOS, and Mobile app access part. Where you can unlock/lock your car remotely. This, I believe requires additional hardware 2) To get other Audi Connect features, such as weather/news/myAudi, I believe you need to have the integrated SIM working with a proper Audi Connect subscription. This, I believes is not available in Canada. 3) In a normal car, Audi Connect in your MMI would authenticate with the server at Audi, once authenticated, it will tap in to the built in features of the MMI which are Google Earth/Traffic/etc. In our car, we don't have the Audi Connect menu which means the authentication part is removed. Because of this, it looks like we are able to directly load Google Earth. I don't currently have an OBD device, but I'd be willing to spring for an OBDeleven in order to try this - I'm sure I could find other uses for it as well. Do you happen to know where to buy OBDeleven in Canada, or would I need to order direct from the manufacturer? |
Tasker
Would you mind elaborating on sharing your setting in Tasker you setup the automatic turn on and off of wifi tethering.
(Post 24909015)
Thanks for the quick reply.
Originally Posted by Johannes Schauss
(Post 24909055)
Step 1 (Create a new Tasker Profile): > Select PROFILES tab > Create a new Profile Name by selecting the + button then select STATE > Select 'BT CONNECTED' in the Select Net State Menu Step 2 (Select the Audi MMI Bluetooth connection): > In the State Edit Menu, enter 'MMI' under name and hit the Search icon > This will returned all the pair Bluetooth profile on your phone. Select the one that matches the Audi MMI > Click the Back arrow, this will bring you back to the main page Step 3 (Assign Wifi Tether Task to Profile): > If you click on the Profile you just created in the profile page, you should see a pop up for 'New Task +' > Click on that, Give it a new name. I named it 'Hotspot' > Click on the + button in the Task Edit menu to add a Task > Select NET > Then Select WiFi Tether > Select ON under the Set menu - This tells the app to turn WiFi Tether ON when the phone is connected to the MMI Bluetooth This is what it should look like at the end: https://cimg4.ibsrv.net/gimg/www.aud...f4def847f1.png |
(Post 24909015)
I don't currently have an OBD device, but I'd be willing to spring for an OBDeleven in order to try this - I'm sure I could find other uses for it as well. Do you happen to know where to buy OBDeleven in Canada, or would I need to order direct from the manufacturer? They do have a Canadian distributor, so you can buy it here. The annoying thing is that you'll shell over 25% of the device cost on taxes & shipping but if you don't want to wait for over a month, then that is the way to go. |
Originally Posted by s_Fanous
(Post 24909115)
I placed an order for OBDEleven directly from the manufacturer over 1 month ago and am yet to receive it. Customs in Canada have been a joke as of late. The reason I placed the order directly from the manufacturer is because they had a very good Christmas deal.
Great idea and thread to combine everything ekyp.
After a few weeks, XM Traffic is still working great on my A4. It provides major highways and major traffic events in the GTA. It is almost perfect! With that said, if anyone can figure out how to get Inrix traffic working, that would be the most perfect solution. Inrix traffic provides traffic information and traffic flow on highways and most roads (similar to Google Maps traffic) where as XM provides traffic flow only on the highways and some traffic information on major issues. Inrix would be slightly more optimal for Navigation as XM Traffic really has no clue of traffic flow once you get off the highways (except in some circumstances). Perhaps it is just a limitation of XM - Maybe they will improve this? If anyone could figure out how to get the External SIM Card or Equivalent for Audi Connect Services working, it could make this the most perfect setup! |
Originally Posted by mlavio829
(Post 24909319)
