Guide: Enable Google Earth/Traffic on Canada spec Audi
#191
I havent tried Google Maps on CarPlay yet but in Toronto I find that Apple Maps is not bad. I especially like it when theres a turn or an exit coming my Apple Watch would vibrate too.
Not sure if Google Maps can do that or Waze....pretty sure thats a first party thing?
#192
Anyone managed to get this to work on a 2018 Q5 in Canada, via phone hotspot? Best I had after trying soo many settings permutation was to get the satellite overlay to appear for about 5 seconds then disappear.
If Remote_HMI or internal sim card is active it will ask for APN and user / pasword... I'm quite disappointed, I bought an OBDEleven mainly for this.
#194
TMC
Hi,
Looking for anyone in the GTA with the OBDELEVEN or valcomm who'd be willing to help me enable the TMC in my A4. Sirius already activated it but I didn't catch on that I needed this until I found this.
Been grateful for the info but didn't want to buy the dongle for a single change.
Much appreciated!!
Aestaie
Much appreciated!!
Aestaie
#195
Hi,
Much appreciated!!
Aestaie
Much appreciated!!
Aestaie
I would be interested to know if you get this working, on mine i set everything including the subscription with XM and TMC code but still not receiving traffic info.
I know it can work since i receive it once in while for like a week or so, seems like they have free Demos or something.
#196
I do OBDEleven programming in the GTA and did this exact mod on a 2018 A4 yesterday. It was a bit tricky and gave me 'something went wrong' errors the first 2 times i tried but i went out, reloaded the module, applied the security access code, and then added the adaptation programming and it took. 34305 worked and added more features for traffic than 1537.
The customer had already called Sirius before they came to me to have traffic added and traffic did not showup immediately after applying the programming and rebooting the MMI. They did a resend from the sirius website for their radio and then about 30 minutes later it started working for them on the dashboard cockpit and center display.
#197
I figured it would be a better idea to consolidate all the information founded by other members in one thread regarding enabling Sirius Traffic and Google Earth on a Canadian Spec Audi running the new MMI.
Canadian cars have no Audi connect features enabled from factory, we have the same hardware as the US cars, but the connected features are disabled via coding. So far, I've tried this on both my own 2017 A4 and the 2017 Facelifted A3 (Both Cdn Spec)
These instructions are not official and are just provided as a mean to share findings from the forum. Make sure you do a backup of the module coding/adaptation and proceed at your own risk
To enable Google Earth (this will require using your mobile phone's data connection as hotspot):
Step 1: Set the following adaptation in module 5F (this can be done by VagCOM HEX-CAN-USB or OBDEleven) :
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts - ON
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other - ON
IDE03471-ENG117843-Vehicle configuration-my_audi - ON
IDE03471-ENG117845-Vehicle configuration-online_dictation - ON
IDE03471-ENG127495-Vehicle configuration-online_media - ON
IDE03471-ENG117840-Vehicle configuration-online_navigation - ON
IDE03471-ENG117837-Vehicle configuration-online_POI - ON
IDE03471-ENG117838-Vehicle configuration-online_POI_voice - ON
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services - ON
IDE03471-ENG117841-Vehicle configuration-online_street_view - ON
IDE03471-ENG117844-Vehicle configuration-picture_navi - ON
IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag - NO_REGION
IDE03471-ENG117836-Vehicle configuration-VZAPro - ON
IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI - ON
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot - ON
Step 2: Restart MMI
Once you've made the above changes, RESET MMI by pushing and holding the toggle to NAV and RADIO at the same time, then press the center **** to restart
While MMI restarts, turn on your mobile phone's WiFi Hotspot
Step 3:
Go to Settings in MMI > Connection Manager > Configure your WiFi Settings in MMI to connect to your phone's hotspot
Step 4:
Go to Navi/Map > Click to the 'Right' Option button > Select Map Settings
Under Display > Click and Select Google Earth
If you've configured a successful WiFi connection, Google Earth should load within 20secs or so
Couple of Notes and Tips:
- I've used Google Earth for a month now, and my data usage on my phone is around 4-500MB for my commute that is 25km one way
- For Android user, I suggest downloading a paid app called 'Tasker'. Tasker allows you to automate settings based on a condition. In this case, I have my phone configured to turn on Mobile hot spot once my phone is connected to the car's bluetooth setting. This allows the MMI to connect to WiFi automatically.
- MMI defaults to the standard map display after your car restarts, you will need to enable Google Earth in map display once your MMI connects to the WiFi (this takes about 30sec).
- Online Search and other Audi Connect features would not work
- I've tried to enable the main Audi Connect menu in the MMI (this is done by setting IDE03471-ENG117846-Vehicle configuration-remote_HMI - ON). Unfortunately, once we added the menu to the MMI main page, Google Earth would not work. I had to turn the Audi Connect menu off again to get Google Earth back.
- I have no tried the SIM slot in the MMI so I am not able to confirm whether or not that would work.
To enable Traffic from SiriusXM (I have not tried this, but another member has so I'll add the info here as well)
IDE05111-Fee-based traffic information (TMC) - 1537
Step 2:
Call Sirius Canada, provide your RadioID and get them to enable traffic subscription.
Sirius traffic working in Canada:
Note:
- Looks like only Sirius Traffic would work. I've tried to use code 65533, 32768, 32771 (these are code for Online Traffic for the MMI) in the IDE05111-Fee-based traffic information (TMC) adaptation. They all enabled the 'Use Online Traffic' checkbox, but none of them shows any traffic information for Canada. Maybe there's another code for Canada?
Good Luck guys!
Step 2: Restart MMI
Step 3:
Step 4:
Step 2:
Note:
Good Luck guys!
Clmartin22 (08-20-2020)
#198
Anyone else able to activate google maps?
Ive configured it. But when I select “google maps” on MMI. It doesn’t load and reverts back to “standard map” when I press back.
#200
