Headlight replacement help
That is it. Not sure what is involved since the rest of the steps are embedded in the Vehicle Daignostic Tester
The headlight lens might have component protection and if that is the case only a dealership or someone with ODIS can change that. However, I thought component protection was only applied to modules and if your modules are original it is not clear that component protection is the problem. Component protection will usually pop up with a message indicating that this is a protected component.
The LED headlights do need to be parameterized; but, that takes place in the control module. If you are still using your original control module it seems like parameterization would not be the issue.
13 is the control module (DRL, turn signals and headlamp hi/Lo)
14 is the headlamp power output module.
The service manual says you need to use the Replace Control Module function in ODIS for the Control Module replacement. Now this is where the labels on the parts and the wording in the service manual collide. In the section on replacing the Power Output Module they have this
It is not clear whether the term "control module" in "If replacing the control module" means the Control Module (part 13) if you happen to be replacing the Control Module at the same time as the Power Module or whether they have sloppy wording and used the term control module to describe the Power Module in this context. So, the Power Module may or may not need adaptation depending on how you interpret the language in the service manual.
If by smaller module you mean the Control Module and that module came with the headlight from the donor car then yes, you are going to have to go through the process of adapting it to your car. This almost 3 year old thread says that the work can only be done using ODIS. However, there is reference that OBDeleven may be developing this capability so you may need to check the OBDeleven web site and it may require the pro version of the application.
Changing a LED control module - AudiWorld Forums
