How to change VC display from A4 to RS4 ?
Old 05-26-2018, 04:44 PM
  #11
R8ready's Avatar
Default Wow
Anyone try the S4 style?
Im guessing you can't have the dial in the center with nav/radio/phone on the sides???
And why no numbers on the speedometer?
Old 05-26-2018, 07:59 PM
  #12
elhalisf's Avatar
I am guessing because the RS4 dial does not have the numbers on the speedometer.
Old 05-26-2018, 11:11 PM
  #13
stanj's Avatar
I haven't tried this, and have no plans to do so, but in the S4 there is an option to switch to the two-gauge A4 style display with center info tab. I forgot where it's buried in the menus, but presumably you would have to perform the process backwards to get to the center one gauge style. It's buried somewhere in the VC display options (not the main MMI) as far as I recall. My S4 has it so the RS4 probably has it, too.
Old 05-27-2018, 07:13 AM
  #14
A4again's Avatar
Can this be done with VCDS?
Old 05-28-2018, 08:07 AM
  #15
Ecastillong's Avatar
Worked perfectly in my A4, was able to do it in under 5 minutes. Thanks so much for the info. If anyone knows how to get the center speedometer or has any theories I would be willing to try them out.
Old 05-28-2018, 08:10 AM
  #16
R8ready's Avatar
Does the numbers show on the speedometer? Both pics yours and the other guys show no numbers
Old 05-28-2018, 08:21 AM
  #17
It does but not when they are small. Take a look
Old 05-28-2018, 08:22 AM
  #18
R8ready's Avatar
Awesome!!
Now we just need the dial in the center lol
Old 05-28-2018, 08:24 AM
  #19
browns_d02's Avatar
Yep...just verified the A4 displays it the same way. Large view has the numbers, small view does not for the speedometer.
If you can’t get the single view, then what’s the benefit of changing it?
Old 05-28-2018, 08:30 AM
  #20
rccoleman's Avatar
Here's how it's done in the S4/S5:
Applies to: vehicles with sport view
- Setting the default view: depending on the vehicle
equipment, you can choose between the
classic and sport view. Select on the multifunction
steering wheel: left control button> Layout
> Sport layout or Classic layout .
You have to have the Audi rings tab selected, the car has to be stopped, and it takes a few seconds to switch into the sport layout.
Quick Reply: How to change VC display from A4 to RS4 ?
