How do you open the door with the physical key? I think my battery is dead.
So I didn't drive my car since Friday afternoon.
Tried to open door by handle, no reaction.
Pressed the unlock button on key fob, the car lights blink twice but no unlock sound.
Tried to unlock trunk with key fob, no reaction.
Tried the manual button on trunk, doesn't open.
Tried the spare key fob, same thing.
Tried the physical key, turned it clockwise 90 degree, doesn't open. Turned it counter-clockwise 90 degree, doesn't open.
What am I doing wrong with the physical key?
Since you B9 A4 is still under full warranty, it is best to have it towed (courtesy of Audi) to your Audi service center and have it checked out. It does seem like your car's battery is toast.
Maybe the keys need to be re-sync'd with the car. Place the key fob on the icon of a key in the center console. Then push the button to start the car. Long shot for the key fobs but worth a try.
OP cannot get inside his/her car due to this issue.
You'll have to request for a flat-bed tow truck although I am not sure how they will get the car on the bed if it cannot be placed on neutral.
I suggest phoning your Audi service center and tell them your car's problem. Also, ask them about how the towing company can get your car on the flat bed without being able to shift it to Neutral.
So I guess the mechanically lock cylinder nowadays doesn't mechanically unlock the door anymore and simply actuates the door locks. That kinda sucks. OP, you are not doing anything wrong. All you can do is turn the key. If the doors don't unlock then there is something wrong with the locks or perhaps indeed the battery is low. Doesn't seem to be completely dead as you still get flashing lights. The energy management system does start to shutdown non essential functions if the battery goes low in order to preserve enough battery power to start the car. However, I would think unlocking the doors with the mechanical key is kinda essential.
As for towing, yes, it needs to go on a flat bed. Never tow a car with a center differential with wheels on the ground. You'll chew up the differential especially if only one axle is on the ground. But even with both axles on the ground and car in neutral there is no oil going to the transmission and the center differential, so kiss good-bye to those gears. They may try to brake into the car in order to unlock the transmission and put it into neutral so the car can be pulled on the flat bed. Worst case they have to drag it up with the drivetrain locked. Not ideal.
Best would be one of these :-)
I'm inclined to blame a major computer problem. Though... stupid idea: did you try the second fob?
Interesting, the Audi manual (p. 372) doesn't mention anything about placing the car in neutral before winching it onto a flatbed. But... I think I may have figured it out how you put a car with a dead battery in neutral - just follow the instructions on p. 95 of the manual for manually releasing the 'parking lock'.
It may be just me but I could not find any reference on this 'disable after 3 days of the car sitting' in the manual. It is not on Page 39 or elsewhere in that section about Opening and Closing the vehicle.
