Low/Mid Frequency Hum
New 2019 Audi A4 experiencing severely annoying low/mid frequency hum around sun roof when the following conditions are met:
1) A/C blower is on and internal air circulation is off (allowing outside air in) 2) Sun roof is completely closed 3) Low/Mid Frequency hum is generated around sunroof mechanism Turn A/C blower off, hum stops If I push the button to circulate cabin air (no outside air), the hum stops. If if I open the sunroof (not slide it open but open it), the hum stops. Any ideas as to what is causing this? |
Given the conditions where you hear it, it sounds like the sunroof isn't completely sealed when closed. Air is trying to escape a crack in the seals and resonating.
Sunroof hum
I have a 2019 A4 with the same exact concern. Ever figure out a fix for this or what was causing the issue?
Originally Posted by Matthew Thompson
(Post 25316239)
I’ve been traveling and haven’t had time to get it serviced. It does drive me a bit crazy. Will let let you know what they find out - should be soon. |
FIXED
Inspected the vehicle seals around the sunroof and all looked good. So I started checking the sunroof drains. BINGO! I found the passenger side sunroof drain valve distorted where it exits the body near the passenger side door hinge, allowing air to bypass into the area around the sunroof. Replaced the drain assembly and noise no longer present.
Awesome! Do I get a cookie?
(Post 25317218)
Originally Posted by BoxerBoi76
(Post 25317229)
Matt, was this something the dealer fixed? If so, is there a TSB for this?
https://cimg5.ibsrv.net/gimg/www.aud...3fe8a7c5cd.jpg
DISTORTED PASSENGER WATER DRAIN https://cimg8.ibsrv.net/gimg/www.aud...c54ce3b279.jpg INTACT DRIVERS WATER DRAIN |
Thank you! I’ll show this to my dealer. Will hopefully save a lot of time.
