need help with obdeleven coding - auto high beams
Hi all,
I have an A5 sportback and just picked up an OBD11. I found the coding, below, to enable auto high beams (or high beam assist) but am getting an error (pictured) in the A5 module when trying to save with “high beam assist”. The error message would lead me to believe I need to set something else besides these settings to get this to work - there’s a prerequisite I don’t have set. Wondering if anyone else has experienced this and found a solution. BTW - I did a firmware update when first plugging in the OBD11, so should be on the latest app and firmware.
Thanks for any help! -Randy
STG 09 - high_beam_functions -> head_light_assistant
STG A5 - AFS_coding_light_assist -> head_light_assistant – getting an error when changing this
STG 09 - mmi_fla_glw_mxb -> active
I used the instructions below which seem to be the same. I had a problem using the easy text system for Active Lane Assist so I had to use the Byte and Bits method. You may want to try that. Its not very intuitive at first but once you do it, it is.
Control unit 09 (central electrical system)> high_beam_funktions> head_light_assistant
(VCDS: set byte 5, bit 5 and bit 6 to 1)
Control unit A5 (sensors)> afs_coding_light_assist> high_beam_assist
(VCDS: byte 21, set bit 5 to 1)
Control unit 09 (central electrical system)> mmi_fla_glw_mxb> active
(VCDS: byte 5, set bit 0 to 1)
Thanks very much. I haven't figured out how to get into the bite,byte coding with this device, is it somewhere in the "long coding" screen? I'm a former vcds user so have coded with this method on that device, just need to figure out how to get to that option and I'll give this a try.
PS - just wondering, I've been making these changes with the car running and the headlights in the auto position, wonder if that's the problem? I'll try it tonight with the car on but not running....
Just wanted to follow-up on this. I tried the coding to module A5 with the engine off and lights also off. So just the ignition on. Took the coding with no problem, so that must have been the issue. Will check functionality when it gets dark tonight, but pretty anxious to see how this works! Thanks to all for the help.
Glad that it worked. I do all my coding with ignition on, but engine off. Do you code with the engine? Auto high beam for me is pretty useless in my heavily urban area, it just senses so much oncoming light that it is off 95% of the time and since it only works at a minimum speed that it doesn't work when I most want to use it in poorly lit neighborhoods and city streets.
I'm in a much more rural area than you (Bucks County Pa) and commute about 40 miles each way to work in NJ, mostly on country roads. Avoiding the wildlife in the winter can be a challenge, so this feature has the promise of being a great safety feature if it works well. Can't wait to find out!
