No response when shifting from R to D
Has anyone encountered a lack of response from the gas pedal when shifting from reverse to drive? The other day I was performing a 3-point turn. While in reverse, I shifted to drive, pressed the gas pedal, and no response. The car continued to slide backwards, almost hitting the car behind me. I had to brake hard. Any possibility there is a fault with the transmission, or is this the nature of the transmission?
When quickly switching between D and R or R and D there is sometimes a delay as you experienced, but this tends to be the nature of dual clutch transmissions.
Are you sure you didnt accidentally go into Neutral? There have been times I thought I pulled back hard enough to go into D(and didnt look down to confirm) and I kept rolling backwards because I was actually in N.
That's a good point. I don't think I did, but I'll double check.
This is like the one thing I miss from a regular automatic with an old style shifter - predictable and fast reverse gear. DCTs and even CVTs have that awful lag, and sometimes you're not even sure the shifter in the right position.
greenie
11
08-30-2005 05:21 PM
Latest communication with AoA (original on bottom, response in middle, response to response on top):
PlacitasNM (aka Ken)
12-19-2002 06:44 PM
AudiOx
09-09-2001 03:38 PM
DrMerl
04-28-2001 05:12 PM
