No ringtone over Bluetooth
iPhone 6 user here. Any thoughts as to why my ringtone isn't being picked up by Bluetooth? Otherwise audio seems fine, but I'm having to keep phone ringer volume high while I'm inside the car to know when I'm receiving a call. In reviewing the MMI menu, looks like there are some options for ringtone, but it says my phone doesn't support it.
Did you try selecting a different ringtone on the phone? The iPhone is one of the phones that support mobile ringtone, which means instead of the MMI playing the ringtone, the phone's own ringtone is played over the car's speakers. Also, make sure you didn't accidentally turn down the ringtone volume on the MMI. There are separate volume settings for the ringtone vs voice. While the phone is ringing, turn up the volume and see if you start hearing it over the speakers.
You can also go into the telephone settings and adjust the various volume levels there. Don't recall exactly where it is, but all the volumes can be adjusted in the settings. You don't have to wait for another phone call. As for the ringtone setting in the MMI, yes that would be grayed out, because the ringtone is coming from the phone itself in your case. The MMI's ringtones such as "Moon" are only used in conjunction with phones that don't support playing the phone's own ringtone over Bluetooth.
Incidentally, I have tried the volume control inside the telephone settings menu (underneath the ringtones,etc.) but to no avail. It is grayed out also, saying the function is not supported by the phone.
So obviously the ringtone volume is different from the volume during a call, as that volume had already been turned up from when I had previously made a few outgoing calls.
