Painted Reflectors
Anyone purchased the TAG color matched painted reflectors? If so, how is the quality in terms of color matching and the result? Do they look “natural/OEM”, like they belong there?
https://tagmotorsports.com/audi-b9-a...r-package-2019 Thinking about getting them for my A4. |
If you have a MY2019, it will not fit.
Audi changed the reflector design on the newer models with the new bumper and TAG has not updated it. |
Originally Posted by Daaavid
(Post 25320604)
Originally Posted by BoxerBoi76
(Post 25320607)
Huh, they clearly state “Fits all 2019+ Audi A4/S4 including S-Line and NON S-Line.”
Someone on the other forums purchased it through TAG and found out the hard way that it doesn't work. The actual reflector itself is a different design as well. Before MY2019, the reflectors were attached via an adhesive into the bracket making it one piece. MY2019 is attached using clips, with the actual reflector being a separate part from the assembly making it a two piece part. |
(Post 25320640)
Not sure where you're reading that, the web page says "2017+".
Someone on the other forums purchased it through TAG and found out the hard way that it doesn't work. The actual reflector itself is a different design as well. Before MY2019, the reflectors were attached via an adhesive into the bracket making it one piece. MY2019 is attached using clips, with the actual reflector being a separate part from the assembly making it a two piece part. Once I do that, I get this: Audi B9 A4/S4 Painted Reflectors 2019+ for Audi A4 2019 Sedan 2.0T Quattro(SKU: 19B9FRONTREFLECTOR)https://tagmotorsports.com/audi-b9-a...r-package-2019 |
(Post 25320643)
I’m reading that after selecting my exact 2019 model on the model selection page. So perhaps the person you referenced in the other forums didn’t drill down into their specific model.
The paint is an OE match as they physically purchase another reflector set, paint it in-house, and ship it out. I'm not sure what color vehicle you have, but if it's anything resembling black, a $5 vinyl wrap will do the job as well. I have DGP, and I decided to wrap it in 3M Gloss Black Vinyl matching the rest of the Black Optics package (e.g. no pearls or flakes in the paint). |
(Post 25320656)
They must've figured it out as well if they have a separate '19 page. If that is the case, then you should be golden. The new reflectors are easier to install, too, as you don't have to deal with an adhesive backing causing it to look uneven after install.
Seems those are no longer "reflectors". Or do they do something that's not obvious?
Originally Posted by PghRich
(Post 25320668)
(Post 25320668)
(Post 25320660)
I have the brilliant black clear coat with black optics. Does the 3M Gloss Black Vinyl match that exactly?
I would even try going to a local vinyl or tint shop and see if they have some leftovers; they can knock it out in 30 minutes for sub-$50. I bought a 5 feet roll for $15 and still have 4.75 feet left. Very easy to DIY. |
