Piano Black Inlay scratches and swirls
Hi folks,
Anyone have success removing scratches and swirl marks from the Audi A4 piano black inlays? If so, what did you use and what was your technique?
I've searched through the forums and read a few things but nothing that says, “this is what worked, what I used and how I did it”.
I'd take a soft swirl mark remover and a foam applicator pad and lightly and sparingly try and buff the inlay. Something like 3M Swirl Mark Remover for dark paints or Meguiars #9 swirl mark remover. You could also try some Mothers Plastic Polish as that is very gentle and could also work.
You don't want to get any of this on the dash, so I'd also tape off the dash, and again, a very small amount should be used.
Mine came with scratches and swirls from factory. It’s very annoying and I tried using a plastic polisher but didn’t help much. After tinting my windows it’s a lot less noticeable. I just left it as is.
Was thinking of getting a carbon fibre cover from eBay. But it would stick out if I don’t change the other black inlays imo.
About to get a ceramic coating put on my car and the shop suggested I could wrap the inlays in black gloss vinyl wrap (or clear) but I don’t know how sensitive it is scratching.
I would like to do a clear wrap but I don’t know how to do that. Getting a company that does car wraps will probably be costly to do but haven’t had a chance to ask
Going to attempt to get the scratches and swirls out myself using Meguiar’s ScratchX and Ultimate Polish - found a post earlier but lost it and and in that post with pics, the owner used these products to remove substantial scratching and swirl marks from his piano black inlays.
I’ve heard of others using various products to remove the scratches and swirls and then wrapping the inlays in clear wrap.
You should see my piano black door inlays... they are scratched to ****s by dealer when I bought it at CPO. Planning on taking them off and polishing with Menzerna 3800.
