Problems with range
do you have the setting above set to [all]
This is the VCDS coding for Removing Key FOB Range Limitation.
Address 46: Central Conv.
Byte 28
UnCheck Bit 1 Range Limitation Lock
UnCheck Bit 2 Range Limitation Rear?
UnCheck Bit 3 Range Limitation Opening
UnCheck Bit 4 Range Limitation Panic
I just UnChecked all 4, but never did testing to see if actual range is gained. If someone can do a unlock / lock test to see what distance it stops working then do this coding and see if range is gained that would nice to confirm.
