Start Stop Feature Disable
#12
#15
worked perfectly thank you upncoming
so i used the apps to disable the start/off options. i clicked active to disable - got the green sucessful pop up. no 100 credits was used. tested my car and still shows the grey A when started.
i went back to apps - and it shows disabled.
for those who coded this. do you guys still have the grey A showing or is it completely gone?
#16
#17
I'm about to give up. I tried everything and nothing works 100%:
Call me crazy but I cant take hitting the button every time I get in the car.
- 5 to 0 in 08-Auto HVAC - works but obviously only when the HVAC is on and I drive with it off more often than on
- The 100 credits in the OBDeleven is just the same mod as above
- I purchased the Kufatec module and it didn't work for me at all. Followed the directions, waited for he Red LED to come on then disconnected, but didn't change anything for me, car still turns off when I come to a stop with the clutch disengaged
#18
Automated button push
#19
My car is manual transmission and works perfectly. Not sure if you long coded something else but maybe you changed something and that is the issue.
Try going back to factory settings and try that change first.
Hope you figure it out
#20
Which did you do, the HVAC setting? And it works with the HVAC off?
