Torsen or Ultra AWD?
#141
This has some info: https://en.wikipedia.org/wiki/Torsen
#142
Also, was I correct that this is false when Ars Technica says, "By default, the engine's torque is slightly rear-biased (40:60), but the mechanical center differential can let up to 70 percent of that go to the front wheels or 80 percent to the rear." I believe Ars Technica was confusing the fact that the Torsen-style differential fully locks when there is a torque difference exceeding a certain amount with it being able to shift 70 percent of torque to the front. It can't do that.
Here's another one (2017 Audi A4 review and road test with price, horsepower and photo gallery):
"The torque split usually runs at 40/60 front to rear, throwing up to 85 percent of the power to the back if necessary."
#143
Well I am not sure. I am asking for help to sort this out.
https://en.wikipedia.org/wiki/Quattr...l-drive_system)
This link says that for Crown Gear, up to 70% can go to the front, and up to 85% for the rear. So I thought maybe they were using Crown Gear numbers for the T3 system. That link does not say how much can go to the front axle, other than saying it can send up to 80% to "one axle." Does that mean the Wikipedia is claiming it can go up to 80% front or up to 80% rear but defaults to 40/60? Why would it be the same 80% max for both front or rear? Seems odd. Also, Wikipedia doesn't say what the default split is for the Crown Gear. Maybe someone who really knows this stuff can update that page.
#144
I never understood Audi press text when introducing the Crown gear diff that said the crown gear reaction is faster (T3 is instant but Crown gear clutch packs are described to need compression which can't be instant).
Further I haven't understood how the "rotational speeds ..result in an increase in axial forces that force the clutch plates to close".
The text about " Once closed, the output shaft is locked .." does apparently not mean "locked" because the torque split should then be able to put close to 100% to one axle if the other is in the air.
From the drawing of the Crown Gear diff it can be seen that the point of contact to the front and rear crown wheels are at different radius. This creates the asymmetric nominal torque split (40/60).
It can also be noted that there are many more clutch discs to the rear which allows the maximum torque split to be higher to the rear than to the front before the clutch begins to slip.
#145
My understanding is that Audi's current diff while based on the Torsen T3 is Audi's own design. It also uses friction discs. Below is a short video that shows the makeup of the diff. I haven't found a similar video that describes how it works like the Crown Gear video.
#146
[AutoZine Technical School] clarifies how the nominal torque split in a TORSEN T3 ("C") is achieved. The planetary gears 'outer' side drives the rear output at a larger radius than the 'inner' side that drives the "sun gear" to the front. It is still not clear to me if the "friction" is constant or changes depending on the counter forces from the outputs.
#147
"Like Torsen C differential, the crown gear differential is default to 40:60 torque split between front and rear axles under normal condition, so it is able to deliver a handling characteristic more akin to rear-drive cars, or in other words, to be less troubled by understeer. When the front axle loses traction, it may send up to 85% torque to the rear. When the rear slips, it transfers up to 70% torque to the front. Such locking range is much wider than the case of Torsen C differential, so it should deliver superior handling, especially when mated with torque-vectoring electronic rear differential as the rear axle now has more torque to play with. Moreover, the crown gear differential is simpler in construction and weighs 2 kg less than Torsen C."
I wonder why they don't put Crown Gear in more cars? I assume it costs more, though this says it is simpler in construction.
