Using Audi Connect service through external SIM in 2017 Audi A4
#11
The data counter on the MMI is useless because it will not differentiate between hotspot data and overall data usage. Who knows what Audi is downloading in the background but it should not matter if you have no clients connected and no SIM in the slot. You can even turn of WiFi clients in the Connection Manager to make sure that nothing is using hotspot data.
Until the next cycle I would turn off WiFi clients, reset the data counter and take a picture of your AT&T bill showing today's data total. Then check again on the 14th and see how things have changed.
One thing I noticed is that my iPhone is set up to only download application updates while on WiFi so it won't use LTE data. Well... The phone connected in the car sees it as WiFi, so away it goes updating apps. That uses a lot of data lately as many of the apps are being refreshed.
Lesson learned... I post this as an FYI to other users. Looks like the data setup is working properly.
OBDelevenPro arriving today, so will look into tweaks next...
#12
OK, turned off the WiFi hotspot in the car so that my personal cell phone isn't connecting anymore. And, what do you know? Voila, zero data used on my personal shared data plan since I did that. Even downloaded a new map update via the MMI. Still no data. So.... Apparently my phone was using a lot of data while connected.
i have a 2017 S3 with the trial Audi Connect service currently. I some how messed up my APN settings when trying to use an external sim (Project Fi). Can you by any chance help me retrieve the factory APN settings? Right now, only Prime Services work but the Hotspot will not give me a connection.
Thanks!
#13
Can anyone confirm that Verizon sim card works? I've been reading a lot on it, and it seems that with the older generations, you had to get the FreedomPop, because of 2G/3G support. I believe the B9 generation is LTE capable, has anyone been successful in adding a Verizon sim card?
#15
Does that mean it will only work when LTE coverage is present (that's most of United States so it shouldn't be a problem), and will both maps and hotspot work?
trops
Canadian Discussion
06-23-2007 08:04 AM
snssns
08-30-2006 12:40 PM
dbtong
08-16-2000 12:50 PM
