What is the screen size of the mmi screen?
https://www.ecstuning.com/b-ecs-part...022565ecs01~a/
I want to order this but it says for 7" screen only and if i measure it diagonal its larger then 7 and its even larger then 7 from left side to right side and its shorter then 7 from up to down
i dont know if i have a bigger screen then other models or if im measuring wrong
There are multiple screen sizes available - I believe North America has 7" and 8" options, and it wouldn't surprise me if there was a smaller screen option in other markets...
I believe if you have MMI Plus with NAvigatino or the tech package then you have the 8.3” screen. Otherwise you have the 7” screen. Check the Audi A4 web site and your maroney sticker and you should be able to figure out what you have.
Even though the screen sizes vary, the actual cutout for the trim is the same. The 7'' screen just has a wider bezel to match the overall size of the 8.3'' screen.
Actually, the overall sizes are different. The 7" screen does not have the silver magnesium frame, and it is more square than the widescreen 8.3" screen which comes with navigation. It's not just a larger bezel around the 7" screen while using the same housing.
