WiFi Tethering with Phone / Hotspot
Is it possible to tether Audi MMI with Phone WiFi, actually making phone's WiFi a hotspot and having MMI connect to it and use it's data?
not that I have seen, no, the car has it's own SIM and data associated with it.
Yes it can be done, I currently am using google earth overlay using wifi hot spot from my phone. It needs to be activated with coding. I used OBDEleven and have used the thread below to get started. Please note I am on a Canadian Spec B9
https://www.audiworld.com/forums/a4-...-audi-2912779/
rilke (03-21-2022)
I would guess yes, but I really can't tell. Try the following and see if the option shows up in the connection manager once you are done. it's easy to revert back if it's not working.
adaptation in module 5F
IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI - ON
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot - ON
I have the google earth overlay working without an Audi Connect subscription or tethering through a phone. Forgot what coding I changed to get it to work though. If enough people want a coding dump I can post it up. Btw I'm not sure what exactly would still work even with a data connection without the prime subscription.
