Windshield wiper streaks/hazing?
I am experiencing a permanent hazy mark that lines up with the windshield wiper when its in the up position shown here. https://imgur.com/a/kLPwi
I have tried using a clay bar, 70% isopropyl alcohol, Invisible Glass, Meguiar's D101 (1:10) with no luck. The surface feels smooth to the touch, no different than the surrounding glass.
There is also a generic haze that seems to coat the entire windshield for about 2-4 seconds after the wipers complete a wipe. It disappears and the glass looks completely clear. In addition, there is a spot on the windshield that doesn't seem to get wiped properly and instead has water smushed across even after the rest of the haziness of the windshield goes away. You can see what I am referring to in this video. https://streamable.com/nl75g
Anyone experiencing the same issues I have here? Any ideas on how to fix them?
Yes, that's dirt and contaminants that get smeared over the windshield. Mix one of those spray bottles with a 50/50 mixture of 90% isopropyl alcohol and water. Use this mixture to regularly clean the glass inside and out with a micro fiber cloth. Forget about commercial glass cleaners. They are all garbage. Then use cotton ***** soaked in isopropyl alcohol (I use 70%) and clean the rubber on the wipers with it until the cotton doesn't turn black anymore or as clean as you can get them. The alcohol/water mixture will over time get that film of your windshield and the clean wipers will avoid smearing more contaminants on it. This regimen has finally mostly cured this issue for me.
Looks like something new to try (Iso/water mix). I've had this issue quite a few times.... Wiper chatter and the streaks during the rain, irk me to no end!
Intersting! May I also suggest a clay bar. I used a clay bar to get find contaminents off the windshield this weekend. Worked really well. But I would give superswiss' try first since that means no investment needed.
Also, I forgot to mention that I usually apply Adam's detailing spray on the outside of the glass after cleaning, which leaves it nice and slick and helps future dirt from coming off easier.
I have already tried using isopropyl alcohol with no luck. Are you suggesting that I need to continue to wipe it over and over again until I see results? I have tried around 5 solid wipes with it and there was no noticable improvement to neither the vertical streak nor patchy wet area.
For example (don't know if this one is any good):
I had similar marks on my original windshield, but that got replaced due to a crack and then the replacement glass got cracked again and replaced, so I'm on my third windshield. I've been keeping this one clean using the alcohol/water mixture and keeping the blades clean to avoid getting it all scratched up again. So far so good after one rainy winter.
No, that stuff won't come out. I believe that's actually fine scratches from the dirt on the wipers and the damage is already done. My suggestion helps it from getting worse and also reduces the film you are getting when wiping. To get rid of those marks and patchy areas you'll have to polish the glass using a glass polishing kit.
For example (don't know if this one is any good): https://www.amazon.com/Glass-Polishi.../dp/B001RAQGXC
Streaking
My car for the same thing since initial delivery. At night in the rain it was really difficult to see. As the wiper passed over the windshield it leave a foggy stress behind. As it was just starting to clear up the wet would move past again and cause the fog again. I tried everything, glass cleaners, alcohol, 3M Easy Erasing pad, clay bar, microfiber cloth. Nothing worked. I sent a lot of time cleaning that windshield.
did some research and bought some "Auto Glass Stripper" from Amazon. That stuff worked great! One application took care of the problem and it hasn't come back. My thinking is that there was some sort of silicone on the windshield. Maybe it was a protectant used during shipping.
