Roof pump gets no power.
I have checked the roof motor power connection on the car and get nothing when the switch is pulled / [pushed at the pump end, tried with the boot lid closed too. Can't find anything sensible online about fuses or relays, I have tried a secondhand roof control module, the problem still exists. I have been to my local specialist and they cannot find any errors on their diagnostic except, no signal to the climate unit. Any ideas?
I am currently working through the same issue-the top had been working and then became intermittent-following the advice of someone I installed a new/used top controller and now it only popps up in the front but the relays for the motor never energize. I did follow one thread and checked the climate control module under the drivers side footwell (its under the carpet in front of the drivers seat) there was some water but I still need to investigate further. If you ever resolved your issue please let me know I would appreciate some direction as right now the only thing I have to go on is an unfounded plausibility error. Thanks
jnsluft
18
11-24-2010 12:32 PM
bianchi
12
05-10-2004 12:43 AM
