2013 A6 VAGCOM Malfunction - 05-Acc/Start Auth. -- Status: Malfunction 0010
OK - I like starting slow and working my way towards final resolution. I know I can post in the VCDS section of this site but it seems to be lightly attended. I will start here, then go there... then go to Ross-Tech. I like sharing in the community for others to find that which I suffer through. So here is one Malfunction that I would like to share. I will add my 2 cents and look for consensus from the real Brain Trust - this community...
Here is a truncated log of this particular malfunction. This is after a complete clearing of all faults (because I was getting a boatload after the 2013 ECM recall of the past couple of months). There were a few drive cycles before I measured again. Here it goes:
__________________________________
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H33 0433
Revision: 00002001
Coding: 0DA82046000000000000
Shop #: WSC 02391 785 00200
VCID: 7BF26FC3FAF6C7E608-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 85349 km
Time Indication: 0
Date: 2017.02.08
Time: 06:46:15
So, this seems to be an Immobilizer Unit.
Immobilizer Unit for 2013 Audi S6|4H0-905-852-C : Audi Wholesale OEM Parts - Audi Genuine Accessories - AudiUSAParts.com e-Store
Looks to be in the steering column? I will check my Shop Manual. But, what should I expect from this failure? All I know is that I have the occasional experience - My Advanced Key sometimes is not recognized at start. The MMI asks me to place the key at the designated point in the interior. Sometimes a second push of the button works. Sometimes I just have to put the key at the point on the dashboard and everything works fine. Another funky thing is that sometimes, the auto-lock on the door handle refuses to work. Unlock always does. I assume that it's a capacitor so it has its own issues. The lock from the fob always does the trick.
So, Immobilizer? Does what? Why would it throw a fault? What should I experience? Here is the link from Ross-Tech:
http://wiki.ross-tech.com/wiki/index.php/Immobilizer
As always, thanks for any assistance before I move on.
AGE
Revision: 00002001
1 Fault Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 85349 km
Time Indication: 0
Date: 2017.02.08
Time: 06:46:15
AGE
When I get this it means my bat. is low in my FOB, and I put in a new bat. and it goes away:
1 Fault Found:
00956 - Key 2
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 74113 km
Time Indication: 0
Date: 2016.08.16
Time: 09:29:55
1 Fault Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 74113 km
Time Indication: 0
Date: 2016.08.16
Time: 09:29:55
Well how cool would that be. Will be replacing said battery tomorrow. Thanks for the reply and heads up. Looking up that 00956 Key 2 addition.
Shall report back.
AGE
Shall report back.
AGE
$.15 each shipped. I keep a few in the car and a dozen in the house.
Hot Fashion 5PCS CR2032 Battery 3V Coin Button Cell For Watch Toys Remote | eBay
AGE
fullbird
A6 (C7 Platform) Discussion
29
01-09-2024 02:38 PM
Stratocaster1422
01-20-2004 01:54 PM
