AudiWorld Forums
AudiWorld Forums (https://www.audiworld.com/forums/)
-   A6 (C7 Platform) Discussion (https://www.audiworld.com/forums/a6-c7-platform-discussion-194/)
-   -   2016 Audi A6 MMI Aux Video Input (https://www.audiworld.com/forums/a6-c7-platform-discussion-194/2016-audi-a6-mmi-aux-video-input-2892220/)
Srivatsan 11-19-2015 08:19 PM
I recently ordered a 2016 Audi A6 p+. I have been following the forums for sometime now.
I understand that on the new 2016 Audi A6, the proprietary AMI connector has been replaced with standard USB ports.
I was wondering if there is any way to hook up an external video source through these USB ports (like for mirroring your smartphone).
I believe this was done using a special AMI cable with composite inputs on the older models.
Thanks,
snagitseven 11-20-2015 05:14 AM
Since the MY2016 has USB ports, you won't need an AMI cable (finally a thing of the past).You'il be able to skip the AMI cable and in it's place you would need an A/V to USB cable, something like one of these:
Otherwise, the other components shown would be needed:
https://www.audiworld.com/forums/aud...creen-2888656/
kj71109 11-20-2015 05:30 AM
I wish they would just make it so I could plug in my iPhone via the USB port and put video(mirror) on the MMI. If anyone has gotten this to work on a 2016, please share. :)
snagitseven 11-20-2015 05:35 AM
Not possible. The MMI does not support mirroring without the components in the link I provided. Video directly from the iPhone using the Apple native video app is doable but not native mirroring.
kj71109 11-20-2015 05:38 AM
Am I missing something on this? I have not been able to get this to work via USB while parked.
snagitseven 11-20-2015 06:39 AM
Be sure your video resolution on the phone doesn't exceed the spec in the manual. I believe it's 720x576 maximum.
schalliol 01-12-2016 09:13 AM
Snagit, have you confirmed post-facelift cars can use this USB AV part and display video on screen? The item you linked would use the USB audio/video codec to pass digital video. You can't pass analog AV over a digital connection like USB.
ahyaman718 02-17-2016 11:06 AM
Why can't you just use a hdmi to usb rather then convert between digital and analog.
schalliol 02-17-2016 11:57 AM
The questions is, does the Audi input take in digital video over USB, and how does it do it? Haven't seen how it works in the '16s. USB is not a typical video interface. If the car does accept video streaming, I assume it happens to use a USB video codec (like USB Audio codec), but typically TVs play files on USB drives vs stream video.
ahyaman718 02-18-2016 05:51 AM
If the USB port supports video the way the AMI used to why couldn't you use one of these http://www.amazon.com/s/ref=nb_sb_no...ds=usb+to+hdmi
