A6 Active Lane Assist Retrofit
#151
Hello Guy's
I retrofitted the lane assist completely from zero, but now I have the following faults in my vcds scan:
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Revision: -------- Serial number: 262130025421000
Coding: EE060000
Shop #: WSC 58466 000 1048576
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 264867F759FCD97442-8072
5 Faults Found:
0552 - Control Module For Camera
C110A 54 [009] - Missing Calibration / Basic Setting
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 238698 km
Date: 2018.04.10
Time: 17:26:07
Outside air temperature: -39.5 °C
Voltage terminal 15: 11.8 V
Control Module temperature: 0.0 °C
0723 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 207
Mileage: 238743 km
Date: 2018.04.11
Time: 11:09:48
Outside air temperature: -43.5 °C
Voltage terminal 15: 12.0 V
Control Module temperature: 19.0 °C
0706 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 238694 km
Date: 2018.04.09
Time: 20:08:55
Outside air temperature: -44.0 °C
Voltage terminal 15: 14.4 V
Control Module temperature: 36.0 °C
0724 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 238694 km
Date: 2018.04.09
Time: 20:08:55
0734 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 238694 km
Date: 2018.04.09
Time: 20:08:55
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H29 0038
Serial number: 000040180505117
Coding: 0440B91C1111
Shop #: WSC 06759 128 28888
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 254A60FB24FAD26C4B-8070
4 Faults Found:
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 207
Mileage: 238743 km
Date: 2018.04.11
Time: 11:09:47
Outside air temperature: 13.5 °C
Voltage terminal 15: 12.3 V
0045 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 207
Mileage: 238743 km
Date: 2018.04.11
Time: 11:09:47
0061 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 238698 km
Date: 2018.04.09
Time: 20:27:13
Outside air temperature: 12.0 °C
Voltage terminal 15: 14.7 V
Control Module temperature: 27.0 °C
0091 - Function Limitation due to Missing Video Data
C1108 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 207
Mileage: 238698 km
Date: 2018.04.09
Time: 20:27:13
Does someone know what i did wrong or how to code all the modules properly?
Coding: EE060000
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 238698 km
Date: 2018.04.10
Time: 17:26:07
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 207
Mileage: 238743 km
Date: 2018.04.11
Time: 11:09:48
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 238694 km
Date: 2018.04.09
Time: 20:08:55
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 238694 km
Date: 2018.04.09
Time: 20:08:55
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Mileage: 238694 km
Date: 2018.04.09
Time: 20:08:55
ROD: EV_BC7.rod
4 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 207
Mileage: 238743 km
Date: 2018.04.11
Time: 11:09:47
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 207
Mileage: 238743 km
Date: 2018.04.11
Time: 11:09:47
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 238698 km
Date: 2018.04.09
Time: 20:27:13
C1108 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 207
Mileage: 238698 km
Date: 2018.04.09
Time: 20:27:13
#152
Having issues
Thanks for the information in your post. I attempted this retrofit last evening. I replaced the Multi function switch with the proper one. I carefully installed my clockspring and now I am getting a ton of error codes. I have tried to re calibrate the steering angle sensor, but my vagcom will not let me do it. It tells me that I have a defective steering angle sensor. Below is the system scan from my car. I dont know if I am missing something ot if I actually ruined my clock spring assembly somehow. All of the buttons work on my steering wheel.
Sunday,22,April,2018,19:03:05:38463
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
Ross-Tech: Home
VIN: WAU3GAFCXCN157524 License Plate:
Mileage: 117892km-73254mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90
VIN: WAU3GAFCXCN157524 Mileage: 117892km-73254miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
84-Night Vision -- Status: OK 0000
85-On Board Cam. -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSI H07 0006
Revision: --H07---
Coding: 1A2A0034056600060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 002007
ROD: EV_ECM30TFS0214G0907551A_002.rod
VCID: 275D00245E7B2B7EF0-8072
5 Faults Found:
6118 - Cruise Control Switch (E45)
P0568 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 95 °C
Intake air temperature: 39 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.780 V
Unlearning counter according OBD: 36
Engine speed: actual: 0 /min
MAF_ENVD: 0.00000 mg/stroke
Coolant temperature (unfiltered): 95.25 °C
Engine: operating status: ES
Engine load: 0.000000 %
Vehicle speed: actual: 0 km/h
7888 - Please Check DTC Memory of Steering Wheel Electronics
P1698 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 117754 km
Date: 2018.04.20
Time: 17:52:23
Engine speed: 700.00 /min
Normed load value: 9.8 %
Coolant temperature: 80 °C
Intake air temperature: 40 °C
Voltage terminal 30: 13.710 V
Unlearning counter according OBD: 40
Engine speed: actual: 864 /min
MAF_ENVD: 228.77646 mg/stroke
Coolant temperature (unfiltered): 37.50 °C
Engine: operating status: IS
Battery voltage: 13.101563 V
6082 - Steering Column Control Module
U0212 00 [032] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
T_AST_ENVD: 0.00 s
Gear: 0
Battery voltage: 11.679688 V
6078 - No Communications with Steering Angle Sender (G85)
U0126 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
T_AST_ENVD: 0.00 s
Gear: 0
6116 - Function Restriction due to Faults in Other Modules
U1113 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 117810 km
Date: 2018.04.20
Time: 23:39:26
Coolant temperature: 84 °C
Intake air temperature: 54 °C
Voltage terminal 30: 11.679 V
Coolant temperature (unfiltered): 84.75 °C
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 P HW: 0BK 927 156 AJ
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16---
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002018
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 3B75CC54B2F39F9E84-806E
2 Faults Found:
12553 - Steering Column Control Module
U0212 00 [040] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
Voltage terminal 30: 11.839 V
Engine speed: 0 /min
Status data bus communication diagnostic interface-State Deashboard received: not received
Status data bus communication diagnostic interface-State ECM received: not received
Status data bus communication diagnostic interface-State ESP received: not received
Status data bus communication diagnostic interface-State Gateway received: not received
Status data bus communication diagnostic interface-State Parking Brake received: not received
Status data bus communication diagnostic interface-State Steering Angle received: not received
Status data bus communication diagnostic interface-State Steering Assist received: not received
12561 - No Communications with Steering Angle Sender (G85)
U0126 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 44A70F0322E5F0C04B00
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 387FD35883C5B48669-806C
2 Faults Found:
0067 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: DB
Uz: 99
0156 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 3A
Uz: B3
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BR HW: 4H0 907 064 BR
Component: BCM2 2.0 H31 0333
Revision: 00002001
Coding: 0D8A2000000000000000
VCID: 7AFB0950F5496696DF-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 2312000056696012
No fault code found.
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H12 0064
Serial number: 10031200040152
Coding: 668320BA5C
ASAM Dataset: EV_AirCondiComfoUDS 002036
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 285F031853652406F9-807C
1 Fault Found:
0276 - Engine Off Timer Performance
P150A 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 142
Mileage: 117810 km
Date: 2018.04.21
Time: 00:02:10
Voltage terminal 30: 12.00 V
Terminal 15 status: Terminal 15 on
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001266883
Coding: 0D072091013E9FE281000884A0003820CF9CD308A209012580 0308453B00
VCID: 77FD1064C65B7BFEA0-8022
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120223 H35 0080
Serial number: 120313010438
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 20121765
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Serial number: 14 03 2012 00001095
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R1ALA02
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0026138933
Coding: 853000
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0001
Serial number: 00000000001203074024
Subsystem 7 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0001
Serial number: 00000000001202243685
Subsystem 8 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103085000001109017
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: E3180F16000000000001
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0001
Serial number: 00000000001203072971
Subsystem 11 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0001
Serial number: 00000000001203072663
2 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:00
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Time Indication: 0
Date: 2018.04.20
Time: 17:52:00
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 N HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0050
Revision: 11001001 Serial number: 55901208301201
Coding: 282904
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3D71C24CACE791AEBA-8068
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Serial number: 00000000000000
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
9 Faults Found:
32256 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:24
Control Module temperature: 44 °C
Voltage terminal 15: 11.897 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
32512 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
Voltage terminal 15: 11.907 V
36608 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:29
Voltage terminal 15: 11.845 V
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
Control Module temperature: 29 °C
Voltage terminal 15: 13.922 V
Velocity_vehicle_reference: -0.02 m/s
Longitudinal_acceleration_vehicle_reference: 0.07 m/s²
136960 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
137728 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
146944 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 142
Mileage: 117810 km
Date: 2018.04.20
Time: 23:39:26
Control Module temperature: 10 °C
Voltage terminal 15: 11.754 V
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 47
Reset counter: 106
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H32 0032
Revision: -------- Serial number: 003D8001YW8D
Coding: 303145313131303030324A55304C34473853
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3365E4749AA357DE5C-8066
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y150001FJN80$
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405R1872OA9FF
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB40611872O4GV8
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB40104UH6IJP2P
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB401I4UHGCL8K8
Crash sensor for front airbag: driver side:
Serial number: 3554VRB406518E5GM99D
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB405T18E5GDOI9
1 Fault Found:
1050117 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 106
Mileage: 117892 km
Date: 2018.04.22
Time: 18:55:27
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LCM0000B
Coding: 0004FC
VCID: 387FD3588BC5B48669-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0009
Serial number: 22 02 2012 D0090765
1 Fault Found:
00778 - Steering Angle Sensor (G85)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 117892 km
Time Indication: 0
Date: 2018.04.22
Time: 18:54:03
Freeze Frame:
(no units): 40.0
Text: 287D4E2000B6FF80F9
Attenuation: 46 dB
Raw, Form. N/A: 000 182 255
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 983 HW: 4G8 920 983
Component: TBenUsaAccNv H79 0416
Revision: 28460177 Serial number: 658230312596024
Coding: 0BCF01064F03D705020100
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
VCID: 72EB2170A5391ED697-8026
1 Fault Found:
16776975 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:24
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000454842
Coding: 00C1033000
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 3467E7689FAD50E645-8060
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790534016
3 Faults Found:
5058 - Steering Column Control Module
U0212 00 [008] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
Voltage terminal 30: 11.6 V
Voltage terminal 15: 11.7 V
Control Module temperature: 49 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
4230 - No Communications with Steering Angle Sender (G85)
U0126 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:22
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
6656 - Control unit for battery monitoring
U1050 00 [008] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 142
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
Voltage terminal 30: 13.7 V
Voltage terminal 15: 13.7 V
Control Module temperature: 30 °C
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0064
Serial number: 28031200040430
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
ROD: EV_ClimaContrUnitRearUDS_002.rod
VCID: 306FEB786BB56CC621-8064
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000025901957
Coding: C0581B008F002001000001010101102030303232203232
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0009
Revision: -------- Serial number: EJ1BPA4204BX6B0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
VCID: 2D51F20C7C87012E0A-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-08
Coding: 0000007
VCID: 3663DD6041D142F67B-8062
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F12.03.1200H020003CZ25163ÿ
Subsystem 4 - Serial number: Z25163ÿ
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:24
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F57225E00628002000413
VCID: 4189BEBCD81FF54EDE-8014
Address 44: Steering Assist (J500) Labels: 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0019454577
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BE17065B95ED657-8066
3 Faults Found:
3158276 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
valid
4215044 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 33
Reset counter: 106
Mileage: 117790 km
Date: 2018.04.20
Time: 21:11:00
valid
4208000 - Steering Angle Sensor
B1168 F1 [137] - Synchronization Failed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 30
Reset counter: 106
Mileage: 117790 km
Date: 2018.04.20
Time: 21:11:00
valid
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0173899875
Coding: 0126063A20FAF48583B00A8002010000000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000078070
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO1572450+
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00001119388
Coding: 010000
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0028
Serial number: WA102905000001126050
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:24
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 B HW: 4G0 035 223 A
Component: BOSE G3 C7 H07 0130
Revision: CJ007000 Serial number: 00000000041069
Coding: 030000
VCID: 1C372FC81F3DF8A66D-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F57225E00628002000402
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000298041
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU57.rod
VCID: 2A5BF9104D691616EF-807E
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 120328-0002-001
Coding: 1223A6601002A400
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 2C57FF08479D08261D-8078
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 C HW: 4G0 035 082
Component: Radio U SIRIU H53 0101
Revision: AB001007 Serial number: 236CT0C7526331
Coding: 020007010000000001
VCID: 204F1B383355DC46B1-8074
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 C HW: 4G0 035 746
Component: H-BNT-NA H48 0423
Revision: -------- Serial number: 031C.0C7534986
Coding: 090200040003EDEF7D168F1E00000003100001000000000000
VCID: 275D0024567B2B7EF0-8072
Subsystem 1 - Part No: 8R0 060 884 AD
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC94015KHR
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LCR000DE
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 142
Mileage: 117754 km
Time Indication: 0
Date: 2018.04.20
Time: 17:52:07
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000010 00000000
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F17224000628002000002
VCID: 4487B7A8C70DE066F5-8010
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 C HW: 4H0 907 441 B
Component: SG Rueckfahrkamera 0161
Revision: --H05--- Serial number: 525 PA8J22G6MV
Coding: 1080013
VCID: 275D0024967B2B7EF0-8072
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 106
Mileage: 117754 km
Time Indication: 0
Date: 2018.04.20
Time: 17:51:58
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:22
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:27
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 P HW: 4G8 959 107 G
Component: HDSG-Modul H13 0039
Revision: 12013001 Serial number: 062200659
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 428BB1B0D519EE56C7-8016
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 G HW: 4G8 919 604 G
Component: HeadUpDisplay 009 0106
Revision: 00000000 Serial number: 00000000000000
Coding: DA0000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7_VW51.rod
VCID: 377DD0648EDBBBFE60-8062
Address 84: Night Vision (J853) Labels: 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0028
Serial number: 0K84AE40067438
Coding: 1411
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 3169EE7C60BF65CE2E-8064
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001206100311
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H25 0036
Coding: 6A060000
VCID: 65C14A2C64F7F96E02-8030
2 Faults Found:
0722 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
Outside air temperature: -42.5 °C
Control Module temperature: 34.0 °C
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 102
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:59
Control Module temperature: 39.0 °C
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 26430D2059713276CB-8072
8 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:24
Control Module temperature: 43 °C
Voltage terminal 15: 11.993 V
Velocity_vehicle_reference: -0.00 m/s
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:29
Voltage terminal 15: 11.976 V
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:53:23
Control Module temperature: 25 °C
Voltage terminal 15: 14.072 V
Longitudinal_acceleration_vehicle_reference: 0.06 m/s²
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:53:23
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:53:23
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 142
Mileage: 117810 km
Date: 2018.04.20
Time: 23:39:27
Voltage terminal 15: 11.828 V
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
Voltage terminal 15: 11.998 V
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000052203127
Coding: 03C198180111
ROD: EV_BC7.rod
7 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
Outside air temperature: 12.5 °C
Voltage terminal 15: 13.8 V
Control Module temperature: 23.0 °C
0043 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
Outside air temperature: 15.5 °C
Control Module temperature: 29.0 °C
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 102
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
0147 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 42
Reset counter: 106
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
0035 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:30
0049 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 146
Mileage: 117770 km
Date: 2018.04.20
Time: 19:57:06
Outside air temperature: 17.0 °C
Voltage terminal 15: 13.4 V
Control Module temperature: 20.0 °C
0170 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 42
Reset counter: 106
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
2 Faults Found:
12583690 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
12584197 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 102
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
2 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 102
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
End-------------------------(Elapsed Time: 06:54)--------------------------
Sunday,22,April,2018,19:11:42:38463
Ross-Tech: Home
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Revision: --H07---
1 Fault Found:
P1698 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 117892 km
Date: 2018.04.22
Time: 19:04:06
Normed load value: 9.4 %
Intake air temperature: 36 °C
Voltage terminal 30: 14.319 V
Engine speed: actual: 672 /min
MAF_ENVD: 92.60000 mg/stroke
Coolant temperature (unfiltered): 84.00 °C
Battery voltage: 14.320313 V
Readiness: 1110 1101
Revision: --H16---
Coding: 000002
1 Fault Found:
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 3A
Uz: B9
Revision: 00002001
Coding: 668320BA5C
Coding: 0045F7
Coding: 02562B
Coding: 853000
Coding: 020300
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Time Indication: 0
Date: 2018.04.22
Time: 19:03:00
Coding: 282904
Coding: 3601010201
4 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
Control Module temperature: 22 °C
Voltage terminal 15: 14.452 V
Longitudinal_acceleration_vehicle_reference: 0.47 m/s²
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
1 Fault Found:
1050117 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:43
Coding: 0004FC
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Time Indication: 0
Date: 2018.04.22
Time: 19:03:40
Freeze Frame:
(no units): 40.0
Attenuation: 46 dB
ROD: EV_RBD4K.rod
Coding: 00C1033000
Coding: 00
Coding: 0000007
2 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
valid
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
valid
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Component: BCM2 2.0 H31 BCM2 2.0 H31 03330333
Subsystem 3 - Part No: 4G8 959 591
Coding: 101F00
Subsystem 4 - Part No: 4G0 947 135 G
Coding: 010000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 030000
Coding: 1080013
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Time Indication: 0
Date: 2018.04.22
Time: 19:03:40
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
Coding: 0A3305C102
Coding: DA0000
Coding: 1411
Coding: 6A060000
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
Outside air temperature: -41.0 °C
Voltage terminal 15: 14.3 V
Coding: 3601010201
3 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
Control Module temperature: 26 °C
Voltage terminal 15: 14.605 V
Longitudinal_acceleration_vehicle_reference: 0.46 m/s²
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
ROD: EV_BC7.rod
4 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:42
Outside air temperature: 18.5 °C
Control Module temperature: 25.0 °C
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:42
ROD: EV_RGS_L.rod
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
ROD: EV_RGS_R.rod
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
End-------------------------(Elapsed Time: 06:57)--------------------------
Ross-Tech: Home
Revision: --H07---
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
P1698 00 [047] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 117754 km
Date: 2018.04.20
Time: 17:52:23
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
T_AST_ENVD: 0.00 s
Gear: 0
U0126 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
T_AST_ENVD: 0.00 s
Gear: 0
U1113 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 117810 km
Date: 2018.04.20
Time: 23:39:26
Revision: --H16---
Coding: 000002
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U0126 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
2 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: DB
Uz: 99
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 3A
Uz: B3
Revision: 00002001
Coding: 668320BA5C
1 Fault Found:
P150A 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 142
Mileage: 117810 km
Date: 2018.04.21
Time: 00:02:10
Coding: 0045F7
Coding: 02562B
Coding: 853000
Coding: 020300
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Time Indication: 0
Date: 2018.04.20
Time: 17:52:00
Coding: 282904
Coding: 3601010201
9 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:24
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:29
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 142
Mileage: 117810 km
Date: 2018.04.20
Time: 23:39:26
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 47
Reset counter: 106
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
1 Fault Found:
1050117 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 106
Mileage: 117892 km
Date: 2018.04.22
Time: 18:55:27
Coding: 0004FC
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 117892 km
Time Indication: 0
Date: 2018.04.22
Time: 18:54:03
Freeze Frame:
(no units): 40.0
Attenuation: 46 dB
ROD: EV_RBD4K.rod
1 Fault Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:24
Coding: 00C1033000
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
U0126 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:22
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 142
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Coding: 00
Coding: 0000007
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:24
3 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
valid
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 33
Reset counter: 106
Mileage: 117790 km
Date: 2018.04.20
Time: 21:11:00
valid
Freeze Frame:
Fault Priority: 2
Fault Frequency: 30
Reset counter: 106
Mileage: 117790 km
Date: 2018.04.20
Time: 21:11:00
valid
Coding: 101F00
Coding: 010000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:24
Coding: 030000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 142
Mileage: 117754 km
Time Indication: 0
Date: 2018.04.20
Time: 17:52:07
Freeze Frame:
Coding: 1080013
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 106
Mileage: 117754 km
Time Indication: 0
Date: 2018.04.20
Time: 17:51:58
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:22
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Time Indication: 0
Date: 2018.04.20
Time: 22:34:27
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Coding: 0A3305C102
Coding: DA0000
Coding: 1411
Coding: 6A060000
2 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 102
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:59
Coding: 3601010201
8 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:24
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:29
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:53:23
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:53:23
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:53:23
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 142
Mileage: 117810 km
Date: 2018.04.20
Time: 23:39:27
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
ROD: EV_BC7.rod
7 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 101
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 102
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 42
Reset counter: 106
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:30
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 146
Mileage: 117770 km
Date: 2018.04.20
Time: 19:57:06
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 42
Reset counter: 106
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
ROD: EV_RGS_L.rod
2 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 102
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
ROD: EV_RGS_R.rod
2 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 142
Mileage: 117791 km
Date: 2018.04.20
Time: 22:34:23
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 102
Mileage: 117754 km
Date: 2018.04.20
Time: 17:51:58
Ross-Tech: Home
Revision: --H07---
1 Fault Found:
P1698 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 117892 km
Date: 2018.04.22
Time: 19:04:06
Revision: --H16---
Coding: 000002
1 Fault Found:
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
VzRef: 00
Bit Info 1: 00
Bit Info 2: 42
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 3A
Uz: B9
Revision: 00002001
Coding: 668320BA5C
Coding: 0045F7
Coding: 02562B
Coding: 853000
Coding: 020300
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Time Indication: 0
Date: 2018.04.22
Time: 19:03:00
Coding: 282904
Coding: 3601010201
4 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
1 Fault Found:
1050117 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:43
Coding: 0004FC
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Time Indication: 0
Date: 2018.04.22
Time: 19:03:40
Freeze Frame:
(no units): 40.0
Attenuation: 46 dB
ROD: EV_RBD4K.rod
Coding: 00C1033000
Coding: 00
Coding: 0000007
2 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
valid
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
valid
Coding: 101F00
Coding: 010000
No Faults Found
Coding: 030000
Coding: 1080013
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Time Indication: 0
Date: 2018.04.22
Time: 19:03:40
Freeze Frame:
Term 15 On
Reverse ON
Count: 4
Coding: 0A3305C102
Coding: DA0000
Coding: 1411
Coding: 6A060000
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
Coding: 3601010201
3 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
ROD: EV_BC7.rod
4 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:42
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:42
ROD: EV_RGS_L.rod
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
ROD: EV_RGS_R.rod
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 117892 km
Date: 2018.04.22
Time: 19:03:41
#155
Once again, thank you for you response.
After googling for more hours than I should, I have come to the conclusion that Active Lane Assist is not supported by the Head-Up display of the A8. What is however puzzling is that all the coding and adaptions for the Head-Up Module are available and accepted when done with VCDS (apart from the first "Personalized Settings - MMI Lane Departure Warning System" as explained above in post #86).
Despite all the hours I've spent on the internet looking for a solution and re-checking all the coding, I have been unable to find an answer to the remaining issue of the flashing ALA icon:
Could this because I've not upgraded the Column Stalk Assembly yet, but used divxman’s post #43-method to activate the ALA? I like the system, but I'm not sure if I like it enough to take the risk of ordering the Column Stalk Assembly and in the end, installing it does not resolve the issue.
Sorry to dig up a old topic, but did you overcome the flashing ALA indicator? After multiple tries I managed to enable ALA on my '18 C7 but the ALA light flashes just like in your video (and it's irritating my missus )
BR,
Cari
#156
Ok, got this to work now. In module 85, the bit 0 and 1 were swapped. Now ALA onic stopped flashing!
#157
Guys, help please...
I'm trying to do the ALA retrofit from scratch.
I don't have ACC.
I wired the camera and managed to get it worked : I can see it in VCDS (address 85 / J852)
For some reason J851 image processing unit is not showing up in VCDS.
There are only 4 pins on it:
1- positive 12v
2-ground
3-flexray
4-flexray
Is there something I am doing wrong?
I don't have ACC.
1- positive 12v
2-ground
3-flexray
4-flexray
#159
Wheel switch reference
Hi all,
I plan to do an active lane retrofit on my Audi A6 facelift of September 2016. I am from France and the car is a French one.
However I don't have Acc.
Could you please help me to have the right spare part reference for the wheel switch?
I saw a lot of difference: I am wondering
-what is the difference between 4G8953502 and 4G0953502?
-can I use one with Acc and being able to have all the features I already have (basic cruise control) + lane assist?
Thanks all for your help.
Note: I would like to retrofit ACC also but looks like that the effort and cost are high.
