A6 Motor Replacement
Long story short, but I have to replace the engine in my 2012 A6 3.0T. I found a 2013/14 S5 3.0T engine. Question I have is, is this S5 motor compatible with my car? Do I need the S5 ECU as well? All all the mounting points similar to my stock 3.0T A6 motor? I plan to upgrade the to the supercharger APR pulley and stage 2 software. Plan to keep my stock A6 tranny and drivetrain.
these are the numbers found on the S5 motor.
CCB005227
063 103 173
Thanks!
CCB005227
063 103 173
Thanks!
If you get it to work that would be great. However it is not like the olden days where engine swaps may have been a bit easier. With the complexities of a modern car I would think you need more than just the S5 ECU. The S5 ECU is almost assuredly incompatible with the A6 tiptronic. Then there is steering and ESP which may be incompatible as well. I'm sure there are many other things as well that would make this a very difficult undertaking, but as we all know anything is possible with enough time and money. Good luck.
I bought the car with a blown engine, got a tremendous deal on it. Not sure how or what happened to it, just know it will be more expensive to fix than to replace. I came across this S5 engine 3.0T, just wanted to know if it were compatible with my car, trans and ecu. I'm assuming it is because its the same platform, with a different ECU which gives it a bit more HP. Torque is the same as the C7 3.0T.
Will be calling Audi tech to understand the difference before investing 7K.
Thanks
Very good! I drag race and been doing it for a while, but by no means a sponsored racer.
Thanks
Thanks
Thanks
Thanks
CCB005227
063 103 173
Thanks!
CCB005227
063 103 173
Thanks!
