ACC and Audi Braking Guard: Unavailable
My car is under the original warranty and when driving down the road yesterday evening I got the message "ACC and Audi Braking Guard: Unavailable" in the dash display. It persisted that evening and this morning as conditions already known to the car at startup.
I've looked up this topic and have seen that others have had issues with this, but when they have had them, either there was some sort of impact or a component was replaced. In my case there were none of these issues, and I don't yet have code info.
I'm going to take it to the dealer, but I was shocked when I was told that if alignment needs to be re-done, that wouldn't be included by warranty. Does that sound right? Without an impact and under normal use, there shouldn't be a need for re-alignment.
Have others had this issue occur seemingly at random, and how has it been handled in that case? Thanks!
I had just washed my car before it rained and then it went off, so I don't imagine that was an issue.
What did they do to resolve it (well, maybe they didn't), and what did any non-warranty charge cost? Thanks!
It was covered under the factory warranty. Then again, it wasn't fixed.
That's good to hear. Did they have to do an "alignment" of the system as part of this? I'm not keen on the idea of a warranty system needing alignment through no fault of my own and having to pay the dealer for that service as they threaten might be needed.
Below are the codes that fired off, which suggests that for some reason an alignment is needed.
Nothing happened to my fully in original warranty car, but I think Audi is going to ask me to pay for alignment. That just seems ridiculous! Has anyone gotten Audi to pay for alignment of these sensors when nothing strange happened to them, or can I do them myself?
Code:
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb Part No SW: 4G0 907 561 A HW: 4G0 907 561 Component: ACC3 H19 0410 Serial number: 00000000000000 Coding: 7601010102 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContrAU57X 002010 ROD: EV_AdaptCruisContrAU57X_002.rod VCID: 2854E60353AF540181-807D 3 Faults Found: 88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 66588 km Date: 2017.03.20 Time: 18:40:22 Control Module temperature: 15 ∞C Voltage terminal 15: 14.711 V Velocity_vehicle_reference: 12.28 m/s Longitudinal_acceleration_vehicle_reference: 0.58 m/s≤ 88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 164 Mileage: 66586 km Date: 2017.03.20 Time: 18:38:33 Control Module temperature: 15 ∞C Voltage terminal 15: 14.693 V Velocity_vehicle_reference: 19.48 m/s Longitudinal_acceleration_vehicle_reference: -0.59 m/s≤ 12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 8 Reset counter: 167 Mileage: 66585 km Date: 2017.03.20 Time: 18:37:54 Control Module temperature: 15 ∞C Voltage terminal 15: 14.791 V Velocity_vehicle_reference: 20.86 m/s Longitudinal_acceleration_vehicle_reference: 0.10 m/s≤ ------------------------------------------------------------------------------- Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb Part No SW: 4G0 907 541 A HW: 4G0 907 541 Component: ACC3 H19 0400 Serial number: 00000000000000 Coding: 7601010102 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContr2AU57X 002008 ROD: EV_AdaptCruisContr2AU57X_002.rod VCID: 2648E83B59BB4271B3-8073 1 Fault Found: 12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 4 Reset counter: 207 Mileage: 66586 km Date: 2017.03.20 Time: 18:38:02 Control Module temperature: 14 ∞C Voltage terminal 15: 14.700 V Velocity_vehicle_reference: 20.93 m/s Longitudinal_acceleration_vehicle_reference: 0.09 m/s≤
I had this 3 times. The first two were because I fixed some scratches on the bumper. The 3rd one is when a stone or another object hit one of the sensor.
Apparently every time when you remove the front bumper or a sensor get out of alignment you need to calibrate the system again. This involves putting the car on a stand and adjusting suspensions and sensors.
This can be done only at Audi and cost $510. I did look if other auto shops have that machine, but nobody in Chicago can do that.
Wow, $510. I can't believe that this should be something that I have to pay for when I'm under OEM warranty when there was no event that happened to my car. Did you have to pay for that under warranty and did you have to pay all 3x?
